  • 1994 - 1995 Specific Tech
Climate Control problems
  • Thread starter Thread starter abusedstang
  • Start date Start date Apr 27, 2005
abusedstang
103
East Hampton, CT
Apr 27, 2005
  • Apr 27, 2005
I recently had a problem with the climate controls. First, it was the fan. Only high works, theres no low or medium, and the second problem is the controller is stuck on defroster. I just now found the problem with that.... the vacuum line from the brake booster to the controller broke inside the engine bay. I'm fixing it right now, but I still have the fan problem. I replaced the switch, but it didnt solve nything. Could it be the fan motor? I hope its not some bad wires somewhere I cant get to. Any help would be great. Thanks :damnit:
89 blue lx
1,936
FSU in tallahassee GO SEMINOLES!
Apr 27, 2005
  • Apr 27, 2005
no there is a relay under the passanger side dash on the blower i replaced mine over the summer is was rusted to $hit i cant remember what its called but if you get under the dash you should find it its about and inch by an inch
94CobraPace
907
Houston, Tx.
Apr 27, 2005
  • Apr 27, 2005
Its the blower motor resistor, Ford only item & is less than $20. It is under the passenger side dash.
abusedstang
103
East Hampton, CT
May 4, 2005
  • May 4, 2005
Thanks
Thanks everyone. After I pulled the glove box, I saw the resistor. When I pulled it out, chunks of rust broke apart in my hand. It was only 16 bucks for the replacement.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
2007 No Heat or AC Control
  • JonScoupe
  • Jan 18, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jan 25, 2025
