  • 1994 - 1995 Specific Tech
clunking noise
  • Thread starter Thread starter rocepp
  • Start date Start date Jun 27, 2005
R
rocepp
15
  • Jun 27, 2005
I recently changed my struts on my 95 GT. changed the passenger side first everything was fine, then changed the drivers side and now i hear a clunking noise when i go over bumps. I know i tightened all of my bolts, any idea what it could be?
WHITE94COBRA
816
HUNTINGTON BEACH
Jun 27, 2005
  • Jun 27, 2005
Is the sound in front or in back? have you checked your sway bars? I know my sway bar in the back broke off and it kept knocking my undercarriage over bumps.
R
rocepp
15
  • Jun 27, 2005
sway bar
it's in the front....sway bar was fine before i changed struts in the front, maybe i'll check it again.
loud 95
562
Milwaukie, OR
Jun 27, 2005
  • Jun 27, 2005
Could be a strut bearing. Find out if it seems to be on one side or the other.
R
rocepp
15
  • Jun 27, 2005
seems to be on the drivers side, which the noise started after i replaced that strut...where would the strut bearing be? is that in the strut?
loud 95
562
Milwaukie, OR
Jun 27, 2005
  • Jun 27, 2005
It is on the top of the strut rod, between two washers right below the sheet metal of the fender. It looks like a washer with a bunch of needle bearings embedded in it.
WHITE94COBRA
816
HUNTINGTON BEACH
Jun 27, 2005
  • Jun 27, 2005
If not the front bearings look into the front bushings, There rubber and can go bad over time.
R
rocepp
15
  • Jun 27, 2005
is it the piece that is about 2 inches long that slides over the top of the strut rod when replacing the top mount? if so wouldnt' i have noticed that with the old strut on there?
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
