  • SN95 4.6L Mustang Tech
Clutch Adjustment Issues
  • Thread starter Thread starter lpraider50
  • Start date Start date Jun 9, 2012
L
lpraider50
18
  • Jun 9, 2012
i have a 97 gt and for some reason my clutch randomly adjust itself. Normally it grabs real close to the floor, but randomly it'll adjust itself and grab high. Any reason why this would happen?
Thanks in advance
98gtDan
48
texas
Jun 9, 2012
  • Jun 9, 2012
i had a similar problem. the stock adjuster was worn out and was slipping and grabing. ordered a double hook and a firewall adjuster and it solved my problem. hope that helped out. http://www.americanmuscle.com/stficaad.html http://www.americanmuscle.com/stdohoqu.html . those are the ones i chose and haven't had a problem out of them.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 9, 2012
  • Jun 9, 2012
If you replace the stock adjuster with an aftermarket quadrent make sure you get a firewall adjuster so you can still adjust your clutch linkage.
The other option is to replace it with another stock unit. They do wear out.
2000fordstanggt
404
Westland, MI
Jun 11, 2012
  • Jun 11, 2012
aftermarkets the only way to go IMHO. a locking firewall adjuster is best, ive used the MM firewall adjuster and it has a tendency to turn by itself. to set it you want to take the slack out then back it off so a penny could fit between the cable and firewall adjuster.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Monday at 11:07 AM
phil2001svt
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
