  • SN95 4.6L Mustang Tech
clutch question
  • Thread starter Thread starter rockyracoon
  • Start date Start date Dec 6, 2010
R
rockyracoon
874
27
49
margate NJ
Dec 6, 2010
  • Dec 6, 2010
im in the process of doing a auto to manual swap in my 96 gt that has a motor from a 2001 gt.
the transmission is a t-3650 from supposedly a 2004 gt,at least thats what I was told when I bought it.the flywheel is from the 2001 motor,so my question is should I ask for a clutch set for a 2004 gt or would any set for 2001-2004 fit?
R
rockyracoon
874
27
49
margate NJ
Dec 6, 2010
  • Dec 6, 2010
well I may have just found the answer to my question,its looking like any clutch kit for mid 2001 to 2004 will fit.I guess the splines are different on the early 2001(t-45 equipped) transmissions.I guess the only thing I have to figure out is if the flywheel will work.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 6, 2010
  • Dec 6, 2010
You will need a clutch that matches the flywheel AND the number of transmission input splines. The stock 2001-2004 came with an 11" clutch.
I am not positive about the number of input splines as I believe it changed. Can you verify the number of transmission input splines?
The 2004 transmission has an OSS speed sensor. I'm assuming that you are planing on getting an extended range Speedcal to make the speedometer work. You should verify the year range that the Speedcal supports. Remember that in 2004, Ford changed the number of OSS reluctor wheel teeth.
E
Everett
22
  • Dec 7, 2010
when i bought my centerforce dual friction they told me that the t45 which came on 99-00 and the t3650 which came on 01-04 were the same size...second hand info
R
rockyracoon
874
27
49
margate NJ
Dec 7, 2010
  • Dec 7, 2010
Thanks for the info everett.
Mr Burns,the listing for the S/C unit at dallas mustangs is from 96-2004,so I guess the reluctor is compatable.
stangalator
18
NY
Dec 7, 2010
  • Dec 7, 2010
i know there is a swap for the tail shafts in the t45's for mechanical to electric speedos. im pretty sure the t45 and 3650 ar both 10 splined. not 100% though.
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
R
Transmission for manual swapping a 1994-1995 GT
  • Rembrant
  • Jul 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 13, 2025
Rembrant
R
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
SN95 4.6L Mustang Tech Mar 23, 2026
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
