  • SN95 4.6L Mustang Tech
code p0133 and longtubes
  • Thread starter Thread starter justinschmidt1
  • Start date Start date Apr 26, 2007
J
justinschmidt1
349
  • Apr 26, 2007
So im pulling p0133 which is slow response from the front sensor....and I have long tubes..
does this mean my 02 sensors are bad or do I just need a tune fore the long tubes?...
J
justinschmidt1
349
  • Apr 26, 2007
and im pulling p1131 and p1151 which indicates lean ...I think its becuase the pervious owner didnt get 02 extenders.
RandyStinchcomb
1,159
Randallstown, Md
Apr 27, 2007
  • Apr 27, 2007
it's because you have moved the O2's farther away from a heat source, common problem wth L/T's a tune can help.
you could try new O2's, Ford does make one wth a longer wire. they are the Motorcraft/Bosch F88Z-9F472-EA
J
justinschmidt1
349
  • Apr 30, 2007
Thanks...but the previous owner didnt use o2 extensions so it gets circuit malfunction on both sides...are these o2 sensors long enough or will i still need extensions?
R
RoadconeTuning
458
Upstate, SC
Apr 30, 2007
  • Apr 30, 2007
what does the tune do to fix this problem?
SilverBullet00
1,150
Wichita, KS
Apr 30, 2007
  • Apr 30, 2007
This is a frequent problem with headers that arent ceramic coated. My stainless steel headers do this as well.
blackfang
1,290
Richmond, Va
May 1, 2007
  • May 1, 2007
How can they be hooked up if there aren't any extensions used?
WRandy is correct. When you go with longtubes the front sensors are taken further back and can cause this. I was running lean with my Longtubes and had a tune correct that issue.
J
justinschmidt1
349
  • May 1, 2007
I think the previous owner tryed cutting and adding to the wires or something..the 02 sensors are not relly working at all...does anyone know if the 02s he showed me will b e long enough without extensions?
RandyStinchcomb
1,159
Randallstown, Md
May 2, 2007
  • May 2, 2007
no you will not as these have 20" of wire
the Ford part # is F88Z-9F472-EA if you want to check them out
Miles
1,225
Burlington, ON
May 2, 2007
#10
  • May 2, 2007
  • #10
The tune allows for a greater length of time for the O2's to warm up, since they are now farther away from the block.
I have issues with my O2's as they never produce a voltage above 0.02v - suspect it's because I am losing too much heat out of my headers.
Stupid cars...
J
justinschmidt1
349
#11
  • May 4, 2007
  • #11
take a look at this
http://www.rockauto.com/dbphp/prt,48,DY843
are these right?doesnt really give me any info just shows what looks to be an extended o2...should I get these?
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon 20 minutes ago
fasterthangas
F
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
