  • 1994 - 1995 Specific Tech
Code Question..
  • Thread starter Thread starter The Hitman
  • Start date Start date Feb 17, 2007
The Hitman
2,541
Orlando, FL
Feb 17, 2007
  • Feb 17, 2007
Ok. The Mustang started sputtering at low speed in cold weather in the last few days. It feels like it's missing. However like I said it runs fine once it warms up and runs strong. It threw a CEL today and I ran the codes, here's what I found.
542 - Fuel Pump circuit open connection - Electronic Control Assembly to ground.
543 - Fuel Pump circuit open connection - Electronic Control Assembly to battery.
176 - Lean on bank #2
211 - Profile Ignition Pick-Up sensor - circuit failure (this code may be old as my PIP went out about 2 years ago and I replaced the distro with a MSD unit and never cleared the code)
556 - Fuel Pump Relay circuit failure.
Now.. I spoke to a friend about it and we figured that it may be the CCRM. But I figured I'd post to get a few opinions.
Thanks.
HISSIN50
34
129
Feb 18, 2007
  • Feb 18, 2007
It is possible the PIP is taking a poopey again. When it cuts out, it can generate a FP code.
For diagnostics, what I like to do is hose down inside the dizzy bowl with electrical contact cleaner. This can clean up the edges of the windows. If the pissy cold weather driving abates for a little bit, that can be a tell. This is highly unlikely to be a fix, but it takes 20 seconds to do.
I agree about your FP relay (inside the CCRM) being suspect, given all the codes. However, it might not be related to the missing issue (that issue is consistant with an engine management issue/sensory input rather than a relay IMHO). As soon as you warm up, you run strong. Relays tend to be more random.
I'd clear the codes and drive it until it burps on you; then pull codes again. Also if it happens to be missing while you do KOER codes, run a cylinder balance test to see if the miss is random of relegated to one cylinder. I'd also want to ohm out the ECT to see if it's calibrated.
Others will have different experiences and suggestions.
Good luck.
Therian
The Highlander
Waterloo, Ontario
Feb 18, 2007
  • Feb 18, 2007
OT: I have no help for you, but I will bump the thread and welcome you back. Long time no see, friend.
The Hitman
2,541
Orlando, FL
Feb 18, 2007
  • Feb 18, 2007
HAHAHAHHAA. Thanks.
Kornnut
1,999
48
108
Tulsa
Feb 18, 2007
  • Feb 18, 2007
Don't welcome him back. He may stay.
The Hitman
2,541
Orlando, FL
Feb 18, 2007
  • Feb 18, 2007
Ok. Went out today and checked all electrical connections to CCRM, ECU, and various other things on the front of the car.
Cleared all codes.
I ran the KOER test while the engine was cold and came up with only one code.
The 543 - Fuel Pump circuit open connection - Electronic Control Assy. to battery.
I also did a Power Balance that came out fine.
I did NOT drive the car down the road.
Any suggestions? Or new opinions?
N
northy_polk
94
  • Feb 9, 2008
Anybody know if he ever figured out what was throwing the code 543?
Thanks,
JD
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
