Computer ship question
  • Thread starter Thread starter gtcobra302
  • Start date Start date Feb 11, 2006
gtcobra302
118
Centra Florida
Feb 11, 2006
  • Feb 11, 2006
I am looking at a couple of hypertech chip on ebay. Which one is better the one that plugs into the port on the computer or the one that goes inbetween the harness and the computer? Is one older than the other?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 11, 2006
  • Feb 11, 2006
The garden variety add on computer chip does little more than advance the ignition timing. You can buy a timing light and do that yourself for much less $$$. Save your money and use it for something better.
Custom chips burned from a Dyno tune are another matter. They are created from the Dyno run on your car with your current configeration. They can make a significant improvment in engines with NO2, pressurized induction, aftermarket heads, cams and intake manifolds.
Since you don't have your mods in your sig, it is impossible to tell what you already have. Here are some budget ways to make your Mustang faster.
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
*1.) I got a metal flange adapter from Powered by Ford for $35 and tax. That was over a year ago. Summit Racing may also have one too.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
HISSIN50
34
129
Feb 11, 2006
  • Feb 11, 2006
Fox or 5N95?
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
T
N ot New
  • TNmach1
  • Sep 18, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 18, 2026
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
