  • SN95 4.6L Mustang Tech
Control Arm Torque Specs
  • Thread starter Thread starter SRT Handz
  • Start date Start date Jun 26, 2007
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Jun 26, 2007
  • Jun 26, 2007
I am finishing installing my 03 cobra front control arms....Does anyone know the torque specs on the Bolt that holt the arms to the K-Member?...and do they need to be tightened under load?
bryan0
175
Bethel, CT
Jun 26, 2007
  • Jun 26, 2007
The Haynes manual says "Front lower control arm pivot bolts/nuts: 141-191 ft/lbs." It doesn't mention anything about tightening them under load.
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
Jun 26, 2007
  • Jun 26, 2007
Thank Ya Kindly
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 27, 2007
  • Jun 27, 2007
Ford Service Maual said:
5. With a suitable jack, raise the front suspension lower arm to a normal attitude position. Remove the compressor tool. On vehicle with 4.6L engine, use care when removing upper plate to avoid nicking the spring coils.
6. With the jack still in place, tighten the front suspension lower arm-to-crossmember retaining nuts to 191-259 Nm (141-191 lb-ft).
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
