convertible top molding
  • Thread starter Thread starter mkkrs1
  • Start date Start date Apr 4, 2005
mkkrs1
49
indian trail,nc
Apr 4, 2005
  • Apr 4, 2005
Has any one ever replaced the molding that goes around the top where the boot snaps in. one of my mounting studs broke and I need to know how you gain access to get to the studs
89-718
rip-cord
162
Alberta, Canada
Apr 5, 2005
  • Apr 5, 2005
I just replaced mine last weekend. Same issue the molding let go so I could not put the boot on anymore. The nuts are hard to get to for sure. There is one between the quarter glass window and the body panel at the front of the trim. I got to that with a small socket and ratchet. There is another one 1/2 the way along where the top connects to the body. And the last two are the real trick one is just at the corner as the trim goes up over the rear deck and the last is right before it connects to the back trim. They are a pain to get to unless you know what you are looking for. You really have to feel for them. I would advise putting in a larger washer if you can, the holes are soo small for the amount of pull a boot can put on the trim. I didn't want it to pull the nuts through or break the mental mounts.
If you already have new trim then I would carefully break the other mounts off so you can see the full picture then you can see exactly where they are and then unscrew them from the top using the broken plastic. The trick is then getting the new trim on. No special tools just patience.
Good luck.
mkkrs1
49
indian trail,nc
Apr 5, 2005
  • Apr 5, 2005
thanks for the help. But how did you get to the nuts. Thru the trunk or inside the car.
Paint and Body Missing windshield molding stud
  • AnthonyA1234
  • Oct 30, 2024
Fox 5.0 Mustang Tech Nov 3, 2024
Mac131
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
