Correct oil pressure reading?
  • Thread starter Thread starter smokinit2
  • Start date Start date Jan 21, 2006
smokinit2
22
Miami, Fla.
Jan 21, 2006
  • Jan 21, 2006
Just installed an FR mechanical oil pressure gauge. (along with voltmeter,watertemp gauges). What should the oil pressure reading be at idle for a 1992 5.0 GT 5spd. Also what's the recommended rpms at idle.Thanks.....
bill302
2,131
alabama,gadsden
Jan 21, 2006
  • Jan 21, 2006
don't know the exact idle oil pressure it should be around 40 lbs. i believe. someone else will verify but manual states 40-60 lbs. at 2000 rpm. recomended idle is 600-650 rpm.
HISSIN50
34
129
Jan 21, 2006
  • Jan 21, 2006
At hot idle, around 20+ PSI is common. At cold start up, 50 ish is good.
As Bill said, the stock idle setting range is ~675 RPM.
Good luck and enjoy the new gauges.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 21, 2006
  • Jan 21, 2006
Ford's recommendation for proper oil pressure is 30PSI @ 2000RPM's with hot oil.
sgarlic
3,085
Jan 21, 2006
  • Jan 21, 2006
Also depends on what viscosity oil you're running. With something like a 5w30 or 10w30, it'll be a little less at hot idle, whereas with a 5w40, 10w40, 15w50, or 20w50, etc, it'll be higher at hot idle.
You can listen to the Ford "specs," but I personally believe that basing your decision about whether your pressure is low or high by reading it at anything over idle gives a false sense of security.
Jeep's "good oil pressure" specs are close to Fords. My 170k+ ZJ runs 30-40 psi at 2,000 RPM, but will drop the gauge to nearly zero at hot idle with anything less than Xw50. That tells me I've got motor issues.. the 2,000 RPM test says it's fine.. which it isn't. Draw your own conclusions.
Now that you have the gauge installed, it's a great opportunity to narrow down what weight oil you really require.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
