  • 1994 - 1995 Specific Tech
Could I do such a thing???
  • Thread starter Thread starter 95Vert
  • Start date Start date Nov 10, 2004
95Vert
1,785
North Mexico (deep south Texas)
Nov 10, 2004
  • Nov 10, 2004
My car is leaking engine oil from in between the tranny and the engine. Has anyone else had this problem? What is it? I'm pretty sure it's a seal or something, but what is it called? Is it too hard to do at my house with a buddy's help??
94TURBO5 O
2,509
VA
Nov 10, 2004
  • Nov 10, 2004
Rear main seal could be the culprit. Check your O-ring on your dipstick also where it goes into the block.
95Vert
1,785
Nov 10, 2004
  • Nov 10, 2004
Thanx, are there any tricks if I decide to do the install or should I just take it to a shop. They're charging me $300.
94CobraPace
907
Houston, Tx.
Nov 10, 2004
  • Nov 10, 2004
I you can change a clutch, you can do a rear main seal. The tranny, bell housing, clutch & flywheel all have to come off. Then it's just a matter of removing the old seal & using the old seal, tap a new one in.
Black70Fastback
319
Dyer, IN
Nov 10, 2004
  • Nov 10, 2004
input shaft of the trans is a possibility too. do you know its engine oil? are you loosing oil on the dipstick? how full is your tranny staying?
more than likely rear main seal though on the engine.
HISSIN50
34
129
Nov 10, 2004
  • Nov 10, 2004
also, if anything on the back side is leaking, it tends to gravitate to between the bell and motor. valve covers are often at fault. i would make sure the PCV is up to par - if it is not venting as well as it should, the pressure can cause seals to leak (and sometimes make a hissing noise). oil pan gasket ok?
i would clean everything up and run it while watching. should see the source of the leak.
good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 10, 2004
  • Nov 10, 2004
He has a good point. Is the fluid red, or dirt brown/black?
You have an automatic transmission, right? So it's definately more tricky than a clutch swap. The AT's are much heavier than the manuals. You need a automatic transmission jack, without a doubt. That way, you can leave the transmission on the jack, remove the driveplate, replace the rear main seal, and then put it all back together.
Sucks to hear man. Good luck with whatever you decide.
Scott
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
