Couple Questions
  • Thread starter Thread starter DRock9
  • Start date Start date Feb 13, 2007
D
DRock9
359
  • Feb 13, 2007
I am getting a free nitrous kit and I can get a new Trickflow Top End kit for about $1,500 so I will probably go that route. My boss however said that putting something like that on my engine would cause problems, like blown headgaskets. He said that it is because since the engine is so old, 120,000 miles, that the cast iron block could have warped a little and the aluminum head wouldn't sit flush on it causing a bad seal and blown gaskets. I was wondering if this was the case, I am going to run a 100-150 wet shot on the motor but I really want to do this HCI because I want more power since I cant put a SC and Nitrous on my car.
Thanks!
85ragtop
BTW, I like dudes.
475
123
NC
Feb 13, 2007
  • Feb 13, 2007
That’s the first I’ve heard of that. I don’t see why you would have a problem.
Mr Grim
58
  • Feb 13, 2007
You might be OK, and you might not. Putting 100-150 shot on your motor will definitely expose any weaknesses. It all depends on the condition of your motor. I would go for it if your motor is strong as it is, and as long as you can afford the fixes (time and $$$) if needed. It will be fun when it's finished!
Good luck!
-Cletus
D
DRock9
359
  • Feb 13, 2007
I would probably only run the 100 shot with the HCI, more than enough power for me. And if I blow too many head gaskets I can always put the old **** back on and use the new **** to build up a motor in the meantime.
Also another question, I got Griggs LCA, Ford UCA, and I am going to get 15inch welds with 275/50/15 Drag Radials...is buying the 10-way ajustable Strange Shocks worth buying to get the power to the ground? I am not sure how much trouble I will be having seeing as I dont have the control arms installed yet but the strange shocks are so cheap. And I like the fact that I can buy a coilover kit for them for $260 total with springs, so I am thinking about going that route. I would like to know because if I will need coilovers in the back I will return the LCA's I just got from Griggs with the spring perch and get ones for coilovers.
Or would I be ok with just getting the shocks and MAYBE springs? I can't find any springs that DONT lower my rideheight because I need to be able to fit a 26"-27" tire under my fenders without them being rolled, maybe I can roll them if it is cheap enough.
Thanks very much!!!!!
EDIT: Forgot to mention this will be a 70% Street/30% Track car, but I just read something about you dont want coilovers in the rear because the shock tower isnt strong enough? Also call me a noobie but what is the point of upgrading the front suspension, control arms/struts/springs, I would think they dont help you out of the hole on the strip as much as they do for cornering...would getting the front struts be neccessary too?
slow93
406
  • Feb 13, 2007
upgrading the front components will help with weight transfer therefore putting more power to the ground in the rear. i really dont see much need for coilovers in the rear on a street car,i have stock upper and lower control arms with lakewood 50/50s and mine does ok..i am about to put some aftermarket controls arms which should help even more.as far as the head gasket questions,i dont think you will have a problem, i have 150,000 on my car and shot 100hp without any problems..then again you never know
D
DRock9
359
  • Feb 13, 2007
Yeah its fine stock but he said if I put new heads on they will blow gaskets. Anyone know about that?
And I am going to call Racecraft tomorrow but I think I am gonna do shocks for now and then upgrade the springs/struts once I figure out which ones let me use a 275/50/15.
D
DRock9
359
  • Feb 14, 2007
Called Racecraft but no answer, anyone know anything about blowing headgaskets if you do HCI?
XavB
74
Honolulu, HI
Feb 14, 2007
  • Feb 14, 2007
off topic...where you getting that top end kit for $1500?
D
DRock9
359
  • Feb 14, 2007
Brand new from a friend who works in a store.
D
DRock9
359
#10
  • Feb 14, 2007
  • #10
ttt once more.
Thanks!
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • brandyn200
  • Jun 20, 2026
AeroCoupe
