  • SN95 4.6L Mustang Tech
Cruise control problem
  • Thread starter Thread starter bert96
  • Start date Start date May 11, 2007
bert96
109
st-jean-sur-richelieu
May 11, 2007
  • May 11, 2007
My cruise control stop working last summer,i don't use it often that's why i waited so long before i start looking for the problem.Where i should looking?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 12, 2007
  • May 12, 2007
Does the horn work, how about the air bag system? If either of those are down then it's most likely the air bag sliding contact or as most people call it the clockspring.
First I would check all fuses and then check the switches on the steering wheel
bert96
109
May 12, 2007
  • May 12, 2007
All the connectors and the air bag are ok,i know that because a couple of weeks ago i changed my steering wheel(FR 500).The horn work also.
steve_stang2003
195
  • May 12, 2007
Can't say for Ford, but the idiots at GM wire the cruise control through the brake switch and then through the rear 3rd brake light.
When the bulb burns out, the cruise control stops working...
Took me a while to find that one on my Chevy even with the FSM wiring diagrams and trouble shooting chart.
Worth a look...
96GTstang46
142
Seattle, Washington
May 12, 2007
  • May 12, 2007
Well we all know that ford makes some weird a** stuff and make somethings work lol..
+1 on that last post.
Also i think it could be that clock spring... same thing happened too me.
Oh do you like that Fr500? I had it but i got rid of it, cuz its too thick and doesnt give you alot of feel for the road. IDK maybe iam on crack or something but yea lol.. good luck:SNSign:
bert96
109
May 12, 2007
  • May 12, 2007
I thought my air bag light would flash if my clockspring does not work??
how can i be sure.....?
I LOVE my new steering,i should do this mod sooner!!
bert96
109
May 12, 2007
  • May 12, 2007
Is it possible to know if the clockspring in my car fit in other ford models ? do they have the same part number?
R
rugster
156
  • May 12, 2007
have you changed your clutch position lately, or swapped to an adjustable cable? that threw my clutch sensor off and mine didnt work right until I re-adjusted it.
bert96
109
May 13, 2007
  • May 13, 2007
i changed my cable 5 years ago and my cruise stop working only last summer.
Mike97gt
it doe snot
10,633
May 13, 2007
#10
  • May 13, 2007
  • #10
If the clockspring was damaged so that the air bag had a circuit fault then yes you air bag light would flash.
I would check the wiring and connector at the deactivation switch ( on the clutch pedal support)
Also check fuses 3 and 6 in the instrument panel fuse box
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
For Sale 2006 Mustang GT Steering Wheel with Cruise Controls
  • lenko
  • Sep 3, 2026
  • Other Classifieds
Other Classifieds Sep 3, 2026
lenko
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1988 GT Lumbar controls not working
  • Fcortes795
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2026
AeroCoupe
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
