Cylinder Head issue
  • Thread starter Thread starter stirling33
  • Start date Start date Jun 13, 2005
stirling33
126
Grayslake, IL
Jun 13, 2005
  • Jun 13, 2005
This I am sad to say is my first post and I would have liked it to be a better situation but I need some suggestions with a problem -
I am installing a pair of Aluminum GT 40 heads and the installation was going flawless until while putting the headers back on one of the threads stripped out....I am asking for suggestions on what to do...i.e. products that can be used, if this has happened to any of you and what did you do to solve the problem.
thanks
R
racingtheburg
23
  • Jun 13, 2005
Heli coil
Make a bigger hole (tap and Die Set)
Weld and tap and die
Hope this helps
anymore question >?
stirling33
126
Grayslake, IL
Jun 13, 2005
  • Jun 13, 2005
Thanks for your response, the Heli coil was the route I was thinking of, what about using a self tapping bolt? Would that be an option or is the Heli coil your best bet.
stangjunkie
381
  • Jun 13, 2005
heli coil!! had a similer problem with a valve cover on my 48 truck... heli coil was the route i took and it worked well that way you can keep all the same bolts al the way round
R
racingtheburg
23
  • Jun 13, 2005
Self tapping bolts would not be good if you had to keep taking them on and off....
rbohm
6,698
550
204
tucson,az
Jun 13, 2005
  • Jun 13, 2005
if you decide you dont want to go the heli coil route, loctite has a product that is like epoxy and is quite strong. i forget the name of the product offhand, but it has been tested in the heat of battle on race motors up to and including top fuel motors. contact a loctite rep as they can tell you the product name.
HistoricMustang
2,359
Confederate States of America
Jun 13, 2005
  • Jun 13, 2005
racingtheburg said:
Heli coil
Hope this helps
anymore question >?
Yep, you can pick up a kit at most auto parts stores. I have two in my block!
The next time you do this go ahead and get a stud kit for the block. That will prevent the in and out, in and out that tends to make holes bigger in most things!
HistoricMustang
www.historicmustang.com/tech.html
T
TT670
360
9
28
Jun 13, 2005
  • Jun 13, 2005
Edelbrock heads are factory helicoiled for this reason. If it were mine and I was pulling the head to helicoil one hole, Id take the time to do them all and be done with it.
M
MitchGT
204
Jun 14, 2005
  • Jun 14, 2005
heli coil. Then use a couple of studs to hold up the gasket and headers while you start all of the other bolts ( or just use studs all around. The only problem with that is that the nuts that go on the studs tend to be much larger than the 3/8" 12 point bolts that I use, and are therefore much more difficult to to get a wrench or socket on,especially with headers involved). I just use the studs while initially putting in the other bolts.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
