  • SN95 4.6L Mustang Tech
Diablo or get 4:10 installed
  • Thread starter Thread starter tra
  • Start date Start date Mar 3, 2006
T
tra
  • Mar 3, 2006
I only have enough money to my gears installed+speedcal or the diablo which would be best?
2002 gt 5 spd
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 3, 2006
  • Mar 3, 2006
Both would be ideal combination...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Mar 3, 2006
  • Mar 3, 2006
thats easy 4.10's all the way
01Steeda
732
Baton Rouge, LA
Mar 3, 2006
  • Mar 3, 2006
4.10's save whats left for the diablo and do the speedcal with the diablo later. just understand you need to watch your speed. I waited 3 weeks between the 3.73's and my tune, I just watched the rpm to judge speed.
menasci
640
Chandler, AZ
Mar 3, 2006
  • Mar 3, 2006
T
tra
  • Mar 3, 2006
I guess no need to be tight with the money I can do the gears and speedcal and when possible buy the diablo and just get rid of the speedcal. Any idea where I can get a speedcal for under 100
LB0193
171
IL
Mar 3, 2006
  • Mar 3, 2006
4.10's for sure
T
tra
  • Mar 3, 2006
I won't need the speedcal if I get the diablo right? and if I don't get the speedcal my mileage is going to jump up
USMstang
114
Mississippi Gulf Coast
Mar 3, 2006
  • Mar 3, 2006
I've got the predator and wish I had the gears! Hell, I wish I would have done the gears right after the shifter.
hognutz
1,940
albany, oregon
Mar 3, 2006
#10
  • Mar 3, 2006
  • #10
well you will feal the 4.10's more but you need to recal for the gears.
I just did the install myself and bought a used diablo off ebay for $250. to help ease the pain of the overall cost.
a gear install as not as bad a people think. I mean the pinion shim off my old 3.27's put the depth right on on my new 3.73's. you could have someone do the bearing swap on the pininos at a shop. If you don't car about the old pinion you can drive it out with a hammer.
you would need the folling tools
torque wrench
inch pound torque wrench
dial indicator
caliper bolts are 15mm
driveshaft bolts are 12mm
the pinion nut is 27mm
the cover bolts are 13mm
the carrier bolts are 3/4
cross shaft bolt is 8mm
magnet for the c clips
shim kit for setting the backlash
3 quarts of 75-140 lube 4oz of friction modifier.
the big thing with a gear install is set the pinion preload. 15inch pounds of roating mass for a old bearing (25 for a new bearing). then put the carrier in. I should go snug no pay but you should not have to drive it in so to speak. torque the carrie bolts to 65lbs and get the backlash .012"-.008". now put the grease on the gears and read the wear patter. backlash is easy. wear patter must be correct. I recomend finding a good shop manual or find something on the internet that really eplains the wear pattern. if it is correct all you do is pull the carrier out ad .005-007 to eash side and then drive it back in place. now you use the dial indicater to verify the ring gear has no more than .004" run out and you done.
the nice thing about doing it yourslef is you know it is correct. shops make money based on an hourly rate and even a not so great gear setup might last longer than they will stand behind it. correctly setup gears go 200K. no shop will guaranty that. I had a shop do gears once. lasted about 1 1/2 years. I was just in a bind and working a ton of hours. I should have just done them myself.
DropTopPony
Noob Slayer
2,570
south jersey
Mar 3, 2006
#11
  • Mar 3, 2006
  • #11
4.10's and a Xcal not a Diablo..SCT is more accessable for tuning.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 3, 2006
#12
  • Mar 3, 2006
  • #12
torque wrench
dial indicator
you are right. it's tough to find somebody to install gears correctly. Every tech I know hacks them.
goshia
252
Mead, Colorado
Mar 3, 2006
#13
  • Mar 3, 2006
  • #13
Note Install of gears are going to run $250 to $450
speed545
458
Montreal, canada
Mar 4, 2006
#14
  • Mar 4, 2006
  • #14
If money is an issue, get the diablo first.
You ll need it anyway after the gear installation.
Speecal would be a waste
01Steeda
732
Baton Rouge, LA
Mar 4, 2006
#15
  • Mar 4, 2006
  • #15
I dont understand the need for the speedcal right away
like I said I went three weeks.. not like it is gonna hurt anything
'03GTinFLA
486
St. Petersburg, FL
Mar 4, 2006
#16
  • Mar 4, 2006
  • #16
Gears first
Save for tuner.
Good way to go.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
D
shift light
  • dirk shorter
  • Dec 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 29, 2025
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
