Disc spindle vs drum soindle
  • Thread starter Thread starter nugget68
  • Start date Start date Feb 17, 2007
N
nugget68
362
  • Feb 17, 2007
what's the difference?
degins
361
Texas
Feb 17, 2007
  • Feb 17, 2007
Disc spindles
A disc spindle has mounting points for a caliper bracket (the bracket is also called an Anchor).
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 17, 2007
  • Feb 17, 2007
Depends on the year however. I believe that from 65-67 they were the same spindle. At least that is what I've been told. From 68 on out there were different.
bnickel
5,640
lubbock, texas
Feb 17, 2007
  • Feb 17, 2007
correct, the 65-67 had a special bracket that bolted to the spindle to "adapt" the calipers which works fine for a fixed caliper. 68-up disc spindles are specifically designed for a floating caliper and the attachment point was designed specifically for that purpose.
fasttback
471
Northern CA
Feb 18, 2007
  • Feb 18, 2007
With the 65-67 that is correct. I was told by many they were different, but my Mustangs are living proof that they are the same.
N
nugget68
362
  • Feb 18, 2007
I have a 68 with drums. If i buy 68 discs the will fit on my spindle? Then I would have to make some kind of bracket for the caleiper? Is this right?
bnickel
5,640
lubbock, texas
Feb 18, 2007
  • Feb 18, 2007
no. the 68-up disc brakes use a totally different spindle. if you're going to use a stock style disc system on your drum spindles you'll need the 67 style disc brakes. the SSBC kits are based on the 65-67 style discs. 67 are slightly different than the 65-66 but use the same style caliper. the fluid transfer lines are bigger on the 67 and the pistons are a little shorter.
the best setup for your car using the drum brake spindles would be the 67 disc brakes.
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
Interest in a bracket to mount 13 cobra disc and calliper on 68 disc brake spindle
  • My68gt500kr
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 21, 2026
My68gt500kr
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
