Engine Displacement
  • Thread starter Thread starter TruRooster
  • Start date Start date Sep 11, 2016
T
TruRooster
  • Sep 11, 2016
Hey Everyone
Y'all know what a safe displacement would be for a 302 5.0 would be when boring out the cylinders? I see a lot going 30 over but would it be possible to safely go over that?
Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 11, 2016
  • Sep 11, 2016
The castings for 5.0 blocks are the thin wall type, and don't have a lot of extra meat for an overbore. Somewhere in the range of .030 to .040 is the max safe range without having the block checked for casting shift. This is a specialized process using a sonic device that has been around for some time.
If you want more cubic inches, a 3.25 stroker crank drops right in without having to clearance the block for the rod bolts.
Reactions: TruRooster and Davedacarpainter
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 11, 2016
  • Sep 11, 2016
347 stroker
Reactions: Davedacarpainter
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 11, 2016
  • Sep 11, 2016
Grn92LX said:
347 stroker
That isn't exactly a drop in replacement; there is some grinding that need to be done to get the rod bolts to clear the bottom of the cylinder bores. You end up installing one piston and rod assembly minus the rings 8 times. That does not include the laborious effort to remove every speck of filings and grit every time you check a rod and piston assembly for clearance. You have to grind the bottom of the cylinder bores; you absolutely cannot grind on the rod bolt heads and expect the engine to hold together at high RPM.
Remember that these are thin wall castings: if you grind too much material, you will either end up with a hole that goes into the water jacket or a crack that starts traveling somewhere else.
T
TruRooster
  • Sep 12, 2016
I'm diggin' the advice guys. I'll probably just go with a 35-37 overbore and throw in a stroker kit to be same. Thanks guys
Sent from my iPhone using Tapatalk
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 12, 2016
  • Sep 12, 2016
The 2 choices for overbore are .030 and .040; there aren't any choices between these 2 sizes.
Reactions: RaggedGT and TruRooster
T
TruRooster
  • Sep 12, 2016
Well then.. Goes to should you how much I know [emoji15]
Ha thanks
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 12, 2016
  • Sep 12, 2016
IMO if possible, I would just hone it out. Very little HP to be gained by boring it out to a 306 vs. the cost of new pistons.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 12, 2016
  • Sep 12, 2016
If you're going to go through the trouble of boring, then you may as well pony up a little extra cash for a stroker kit. You'll have to buy new Pistons either way....what's another few hundred bucks for better rods and crank while you're at it. You can stroke that engine for about $1,000. Decent Pistons will easily eat up $300-$400 of that.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 13, 2016
#10
  • Sep 13, 2016
  • #10
My 347 short block was just over $2,000 all in. Scat crank, probe pistons, probe ultralight I beams, arp rod bolts & main cap studs ect..
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 13, 2016
#11
  • Sep 13, 2016
  • #11
How long ago was that? The price of almost everything goes up every month.
The only that that has gotten less expensive over the last year is the cost of a gallon of gas...
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 13, 2016
#12
  • Sep 13, 2016
  • #12
I bought my CHP rotating assembly for $880US about 4-years ago (balance included). Depending how you get it balanced, you may need to buy a new dampener and flywheel (if you go with the 28oz or zero balance option vs the standard 50oz.)
I think the same kit is about $250 more now?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 13, 2016
#13
  • Sep 13, 2016
  • #13
My kit was around $1450 balanced. Scat crank and rods, Mahle pistons. I think the pistons were about $750 of that cost.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
G
Anyone in North Carolina...
  • GOvert
  • Jun 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GOvert
G
Glad to be here
  • josep4
  • Aug 7, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
DadLife0724
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
