DOES ANYBODY KNOW????????????????
  • Thread starter Thread starter yourtransamsuck
  • Start date Start date Aug 2, 2004
Y
yourtransamsuck
17
Eglin AFB FL
Aug 2, 2004
  • Aug 2, 2004
what all do you have to do to convert a 1987 lincoln roller block to a H.O. I know you need the e-7 heads but what else? is there any block prep?
9
93-2.3
99
PA
Aug 2, 2004
  • Aug 2, 2004
isnt the roller motor out of like an lsc already an H.O. built to the same specs as a stang motor?
L
LQQKIN4COUPE
41
  • Aug 2, 2004
Yeah if it's a Mark VII motor it should be HO if it's out of a town car it's a standard 302
squeeeg
1,905
Michigan
Aug 2, 2004
  • Aug 2, 2004
If it is the HO motor it is already the same as the one in out mustangs. If it isn't the HO then you need to change a lot. For starters and not even close to all you will need heads, cam, intake, crankshaft, lifters, that spider looking thing that bolts into the block (which will need to be drilled and tapped)
Y
yourtransamsuck
17
Eglin AFB FL
Aug 3, 2004
  • Aug 3, 2004
what all block prep do i have to convert to a H.O.
thanks for the info! what about the firing order?
dastang2
2,020
tx
Aug 3, 2004
  • Aug 3, 2004
the cranshaft does not need to be changed to change to an HO, the cam is what changes the firing order.
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
