Does engine need to be grounded?
  • Thread starter Thread starter stock88
  • Start date Start date Jul 7, 2004
stock88
125
upstate NY
Jul 7, 2004
  • Jul 7, 2004
When my motor was replaced, the shop took the little ground off the back of the motor and never put it back on- does this need to be put on, or does it not matter? Is this the only engine ground on the Mustangs? Could this be robbing me of power? Thanks for any info.
rsw007
469
Lexington,SC
Jul 7, 2004
  • Jul 7, 2004
yes it needs to be hooked up. i think its the ground for your injectors
88stangmangt
2,332
Stafford,VA
Jul 7, 2004
  • Jul 7, 2004
all grounds need to be hooked up....................
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 7, 2004
  • Jul 7, 2004
Grounds are important to any electrical system, and especially to computers.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
3.) The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
HISSIN50
34
129
Jul 7, 2004
  • Jul 7, 2004
in addition, it cant hurt to run another ground or two. i plan to. gives you some cush if another gets some resistance. plus the thing is marginally grounded in all probability(why would it be different than the rest of the wiring. LOL).
the Heater ground for the lambdas is often left off (as JR said).
R
RustyFox
44
Media, PA
Jul 7, 2004
  • Jul 7, 2004
If you have solid motor mounts, you should be ok, but you can't have too many grounds. Be safe and hook it up.
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
