drain plug problem
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Oct 20, 2007
M
MattTheBat83
203
  • Oct 20, 2007
im pretty sure i cross threaded my drain plug now it leaks like crazy... any way to fix this?
corvetteguy
71
  • Oct 21, 2007
Check with auto parts stores.
They all have larger threaded
plugs.
L
lang williams
567
cleveland, oh
Oct 21, 2007
  • Oct 21, 2007
run a tap into it to fix the threads. i picked up a cheap set for like $6.00 for little jobs like that.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 21, 2007
  • Oct 21, 2007
you can rent magnetized tap sets from autozone for like $45. as stated above tap it out for a bigger plug then install a new plug. i wouldnt recomened stripping a bigger plug into the existing hole. it might work might not, but i dont recomened it.
Block draining
  • JD1964
  • Mar 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2026
JD1964
  • Mindseye007
  • Aug 16, 2026
Mindseye007
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Engine How does oil make its way into the front sump?
  • Sock_Monke
  • May 10, 2025
Fox 5.0 Mustang Tech May 22, 2025
Chuckster101
C
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
