DRIVEABILITY EXPERTS NEEDED!!!
  • Thread starter Thread starter SLOW 97
  • Start date Start date Sep 3, 2004
SLOW 97
667
Arlington Heights,IL
Sep 3, 2004
  • Sep 3, 2004
Alright here we go...90' Lx droptop. 306. Long story short, did a complete rebuild. motor is in, everything is hooked up. all the connectors, checked all the grounds, they're all hooked up. FUEL PUMP DOES NOT PRIME when the ignition is on...BUT it does prime when we jump the wires (pink/black, & Green). (SO the pump is fine). Checked the inertia switch for continuity, and checked for voltage goin in and out of it. Passed. We figured out the problem is not past the fuel pump relay, that possibly it is sticking, but we tested it, and it is getting voltage with the ignition on (12.6 volts). We have narrowed the problem down to the control side of the fuel pump relay. Help me. Thanks in advance.
SLOW 97
667
Sep 4, 2004
  • Sep 4, 2004
anyone?
HISSIN50
34
129
Sep 4, 2004
  • Sep 4, 2004
the puter sends ground to the neg coil of the relay to energize it. sounds as though you might be missing your ground. Jrichker has a real nice write up on testing it all out.
do you have ground at the relay from the puter (should be the only ground)?
good luck.
giddyup306
3,041
Sep 4, 2004
  • Sep 4, 2004
I say your relay is bad. Try jumping across the relay. Just because you have voltage to it does not mean that it is functioning properly. It shouds like the contacts are shot.
SLOW 97
667
Sep 4, 2004
  • Sep 4, 2004
I've tested the relay. It's fine. 60.5 ohms on the coil side and open on the contact side. Unless the relay is sticking, it should be fine. And yes iam aware that the EEC creates a path to ground which will energize the relay. So I'm thinking it's gotta be a computer problem. The relay does not click at all when the key is turned to the "run" position. I dunno, I'm thinking of just rigging up a switch to run the pump directly of battery voltage. I guess this is one of those times I wish it was carbureted. Oh well, EFI still rules.
SLOW 97
667
Sep 4, 2004
  • Sep 4, 2004
I Tried putting a new relay in...Fuel pump still not priming. At least this dancing banana will cheer me up...
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 4, 2004
  • Sep 4, 2004
The grounding transistor in the EEC is probably shot. Manual switch or a realy slaved to the ignition switch "on" position.
HISSIN50
34
129
Sep 4, 2004
  • Sep 4, 2004
great answer Tom. i like the slave relay idea.
Slow 97 - i did not mean to offend (about the puter sending the ground pulse to the relay coil). problem with the forums is we dont know what the person on the other end knows.
giddyup306
3,041
Sep 4, 2004
  • Sep 4, 2004
Then use a HIGH IMPEDANCE DVOM to test for voltage at the ECM cavity. If you don't you might let the white smoke out of the computer. We all know that the ECM works on white smoke.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2004
#10
  • Sep 4, 2004
  • #10
Fuel Pump Troubleshooting for 87-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...witchWiring.gif
http://www.veryuseful.com/mustang/t...inks-ign-ac.gif
http://www.veryuseful.com/mustang/t...91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition switch wiring or connections. There is a mystery connector somewhere under the driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If all of the checks have worked OK to this point, then the computer is bad. The computers are very reliable and not prone to failure unless there has been significant electrical trauma to the car. Things like lightning strikes and putting the battery in backwards or connecting jumper cables backwards are about the only thing that kills the computer.
SLOW 97
667
Sep 7, 2004
#11
  • Sep 7, 2004
  • #11
Yeah I think im going to just energize the relay off the switched 12v source from the ignition switch. Kinda ghetto, but it will do the trick. We've tried everything, it's gotta be the EEC and I dont think my buddy wants to buy a computer. Magic computer smoke=bad news.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 7, 2004
#12
  • Sep 7, 2004
  • #12
Don't just guess at it, follow the test path and you will find the problem. I have 95% or better sucess rate in using it to find the problems.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 7, 2004
#13
  • Sep 7, 2004
  • #13
I would try to fix it right - try Jrichker's procedure.
SLOW 97
667
Sep 8, 2004
#14
  • Sep 8, 2004
  • #14
I think you guys are missing the point, I'm not guessing! Everything in the fuel pump control circuit is fine. The only possibility is the computer. It's very possible it's fried. The first time we went to crank it over, one of the ground wires off the neg. battery post started smoking and the wire was very hot. So there was a short somewhere. The next day when we could actually see, (Don't do an engine swap in the dark! ) we noticed we forgot the ground that attaches to the front of the block. This is why i think it's a computer problem. Solid state components don't like voltage spikes which is exactly why the computer dosn't supply power to actuators, it only controls the path to ground. I'm going to double check everything again though just to be sure. Don't want to replace a perfectly fine computer. That's a last resort.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 8, 2004
#15
  • Sep 8, 2004
  • #15
If it is the computer, then you may choose to do the slave relay. I would probably do that rather than buy a new computer that was otherwise OK - but you don't know that yet right?! You may wind up buying one anyway. Do a temporary jumper from the switch ot the fuel relay to see if the EEC will run the engine.
SLOW 97
667
Sep 9, 2004
#16
  • Sep 9, 2004
  • #16
Yep that was my plan exactly. I'm going to see if it will run. I know for a fact it is the computer now. Jumped the test connector to ground, relay clicks, pump runs fine. I know we need an A9P. Will a computer out of a '90 Cougar work? Cause I can get that for free. I'm not very familiar with the differences between Fox computers. The Cougar is non HO, but will that EEC work?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 9, 2004
#17
  • Sep 9, 2004
  • #17
Non HO computers will have a different firing order, and different fuel, & spark advance numbers. Not a good choice.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
