Dumb Fan Question
  • Thread starter Thread starter Shirley
  • Start date Start date Nov 9, 2005
Shirley
112
Phoenix, AZ
Nov 9, 2005
  • Nov 9, 2005
Just got a 16'' electric fan on ebay, came from a lincoln. It is a two speed, and came with a wiring relay kit. I do not want to use the two speeds, only the high speed. I can't figure out how to wire it so that it only comes on after the car is started. As of now, the high speed wire is connected to the positive starter relay, and the ground wire is connected to the negative starter relay, this obviously isn't the right wiring because the fan comes on as soon as i ground it. HELP!!!!
HISSIN50
34
129
Nov 9, 2005
  • Nov 9, 2005
What is a negative starter relay? Is there a switch in the circuit?
You should use the controller or at least the relay so you dont burn up switches. With the relay, you can use nearly any key-on power source you want, since it is only drawing enough energy to energize the relay (as opposed to powering the fan itself).
Also, I would wire the low speed up. Fans are not generally made to go from off to high speed. Doing this can shorten the life of your new fan.
A DcControl unit would take care of all this, but it is probably not in the budget. If so, I know the feeling.
Good luck.
rd
3,316
63
109
Ocean Springs MS
Nov 9, 2005
  • Nov 9, 2005
Electric fans need a relay for power, or you will have to run like 8 gage wire to the switch.
Install a relay for the fan, 30 amp works for most. It has power from the battery, (install a fuse in this wire), and a wire to the power terminal of the fan.
You can then run a switch from inside the car, which you power from some circuit that is hot only when the key is on. The best way is to run a switch, and then in series, run a temperature switch that turns the fan on when the engine heats up and off when it cools.
Slo 5.0
144
St. Louis
Nov 9, 2005
  • Nov 9, 2005
Hook one of your wires (positive?) into the fuse box, the fuse for the ignition i think. my friend did it for his and it works. It only comes on when the key is forward.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
