dust shield removal
  • Thread starter Thread starter notched1
  • Start date Start date Dec 11, 2004
N
notched1
31
ontario,canada
Dec 11, 2004
  • Dec 11, 2004
Just purchased new front rotors for an 89. Small thing, rotors(Raybestos)are correct in everyway except for the external casting on the inboard side rubs very slightly on the dust shield(flanged portion).Bearings are also correct(A5 and A12) Yes, I know Ford are much better rotors but I only need these till spring then its being converted to 5 bolt, so I went cheap. Other than better rotor cooling is there any other pros/cons I should be aware of if shields are removed ?? Car is daliy driver. cheers
87'GTstang
1,025
  • Dec 11, 2004
Dust shields help keep water and contaminants off of the rotors. Try to just bend them back a little. I don't know why you are calling Raybestos cheap, they are a good, quality company that has been around for years. If you must remove them, it should be about 3 screw/bolts to take them off.
N
notched1
31
ontario,canada
Dec 11, 2004
  • Dec 11, 2004
Thanks for the info , maybe inexpensive is better put. 'Cheap' in comparison to OEM stuff....
@#$%!! Should be simple! Raybestos 6984R Rotors, hit dust shields! DANGIT!
  • JasonRP
  • Sep 9, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2021
7991LXnSHO
D
How to remove the differential from a 94 Mustang GT Coupe
  • dcm0123
  • Apr 10, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2022
dcm0123
D
D
2000 GT, upgrade front and rear brakes to Cobra
  • DIss
  • Jul 11, 2021
4K
1996 - 2004 SN95 Mustang -General/Talk- Jul 15, 2021
Mustang5L5
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
