easier to pull trans out too?
  • Thread starter Thread starter sidewayzisbest
  • Start date Start date Oct 3, 2004
sidewayzisbest
427
Lexington, SC
Oct 3, 2004
  • Oct 3, 2004
Well im having oil pump/shaft problems and have to replace it =(. I was wondering when i take the motor out would it be easier to pull the trans out also? and any tips on replacing oil pump? thanks
RYC CUKR
1,437
Orlando
Oct 3, 2004
  • Oct 3, 2004
In my experience it has always been easier to pull the motor and tranny out together. I pulled just the motor once and played hell trying to get it to line up with the tranny when putting it back in. It is a little more work to pull both but I think in the long run it will be easier and less frustrating. As far as the oil pump no help there, never had one go. Knock on wood.
Smokedawg
2,260
Oct 3, 2004
  • Oct 3, 2004
I have always found it easier to pull the tranny with it. I have tried replacing the oil pan by jacking the motor up but ended up pulling the motor anyway. I would just pull them out together..
Good luck!
-Smoke
MrKwik
1,008
Kansas City, Kansas
Oct 3, 2004
  • Oct 3, 2004
I changed the pump and shaft in my 89 when the shaft failed and I did it in the car. I just removed the mount bolts and lifted the motor up with a cherry picker and stuck a big floor jack under the ballancer in case it decided to come down for some reason. Took about an hour and a half of I remember. Its not much fun but it is possible and faster than pulling the motor.
ALMOST STOCK
1,250
41
88
CA.
Oct 4, 2004
  • Oct 4, 2004
I've always pulled the trans w/ the motor, it just seems to be easier and quicker in the long run.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 7:51 AM
AlexM556
A
