EDELBROCK E-FORCE COMPLETE SUPERCHARGER KIT 2005-2009 **$700+ PRICE DROP:omg:**
Complete Edelbrock E-Force Supercharger Kit for 2005-2009 4.6L 3V Mustang GT.
The new 50 state legal Edelbrock E-Force Supercharger System will allow you to boost your Mustang to a very impressive 466 horsepower and 439 ft./lbs. of torque. This system was exclusively designed by Edelbrock to provide instant, reliable and safe horsepower for a stock Mustang 4.6L with only 5 psi of boost for minimum stress on the engine.
The core of the system is the all new Eaton Gen VI TVS® supercharger rotating assembly. Eaton’s assembly features a four lobe design with 160° of twist for maximum flow, minimum temperature rise and quiet operation for excellent drivability. The supercharger assembly has been integrated into the intake manifold for a seamless design with minimal components, eliminating the possibility of vacuum leaks between a gasket surface. Edelbrock’s unique inverted supercharger assembly is placed low in the valley, allowing for an incredible industry leading 15" of intake runner length for maximizing low end torque. An integrated bypass valve helps eliminate parasitic loss under light throttle for improved mileage potential.
The system breathes through a specially engineered 85mm electronic throttle body matched with the most unique and efficient inlet configuration on the market. This combination results in a shorter less restrictive intake path for improved air flow, eliminating the need for a jack-shaft. Keeping the air cool is a 110 square inch high capacity air to water intercooler and dual core low temp heat exchanger. This intercooler is the largest available on the market today. Clears factory Bullitt strut tower brace and most aftermarket braces.
- 2005-2006 Mustang owners will also need EDL15804 Edelbrock Cooling System Upgrade Kit.
- 2007-2008 Mustang owners need no other components.
- 2009 Mustang owners will also need EDL15805 Edelbrock Supercharger Hardware Kit.
THIS SALE WON'T LAST FOREVER AND WE DO NOT KNOW HOW LONG WE CAN GIVE THIS PRICE SO GETS YOUR TODAY WHILE YOU STILL CAN FOR THE UNBELIEVABLE LOW PRICE!!
CJ Pony Parts 2005-2009 Mustang Edelbrock E-Force Supercharger Sale
