EGR Block off plate?
  • Thread starter Thread starter MAC'n89Blckstng
  • Start date Start date Jul 20, 2004
MAC'n89Blckstng
1,012
NJ
Jul 20, 2004
  • Jul 20, 2004
Does anybody know of a company that makes an EGR block off/delete plate? Someone told me they exist but do not know who makes them.
Thanks,
Jesse
shttygtstang
978
  • Jul 21, 2004
look on ebay there cheap you also need a diode youll see that on ebay if you dont use the diode youre car wont run right you realize theres no power gain from doin this
MAC'n89Blckstng
1,012
NJ
Jul 21, 2004
  • Jul 21, 2004
well, there would be a power gain if my EGR is sticking open since its shooting Hot exhaust gases back into the combustion cycle. I just want a cheaper way to solve this than getting a 90 dollar valve.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 21, 2004
  • Jul 21, 2004
Why do you think the EGR is leaking? What codes did you get? Remove the EGR and see if you can blow air through the flange side of it by mouth. If not, it is a sensor or wiring problem
EGR reduces combustion temperature, and octane requirements in cruse mode. Some engines will develop a part throttle ping because the EGR is not present or working. The EGR closes when you got WOT (wide open throttle), so it has no effect on full throttle performance.
If you are going to remove the smog equipment (Cats, smog pump, EGR, etc.) plan to have a custom chip burned to eliminate the trouble codes and possible limp mode operation associated with them.
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
