egr block off
  • Thread starter Thread starter whitemustang89
  • Start date Start date Jan 3, 2004
whitemustang89
166
in the sticks of arkansas
Jan 3, 2004
  • Jan 3, 2004
do any of you guys have an egr block off plate? where did you get it? can one be made? was it hard to get all the egr stuff off? thanks for any advice. im wanting to get rid of mine b/c in arkansas no emissions! and i think it would solve my miss
Black 93 Fox
1,995
Vancouver,Washington
Jan 3, 2004
  • Jan 3, 2004
Yeah i would like to know also. couldnt you just take a piece of metal trace it and then cut it drill the two holes and put it over the space with some gasket maker to seal it? Also wouldnt you plug the line going to the 4 square thing?
stang1989
211
  • Jan 3, 2004
UPRproducts.com makes the plate, it's made from billet aluminum (at least mine was, now I think they are stainless steel). It was $20 or so when I bought mine. YMMV
Make sure you have a custom chip or modify your ECU so it doesn't use the EGR anymore. I have zero emissions devices on my race car and the difference is primarily seen in the ease with which one can maneuver about the engine bay without creating a mess of vacuum lines and you also lose a substantial amount of weight.
whitemustang89
166
Jan 3, 2004
  • Jan 3, 2004
i dont really know that is what i was wondering but you know how some homemade stuff goes some times
Matt90GT
3,055
Oregon
Jan 3, 2004
  • Jan 3, 2004
http://www.ronmorrisperformance.com...=CTGY&Store_Code=rmp&Category_Code=Spec_Parts
cardudeusa
1,744
Home of the Florida Gators!
Jan 3, 2004
  • Jan 3, 2004
I just got a egr eliminator plate that gets rid of the entire erg plate. Looks alot better too.
StangTtops88
38
Wichita, KS
Jan 3, 2004
  • Jan 3, 2004
I made one myself. I had a small piece of aluminum that I didnt need. Traced it to the same size as the gasket and drilled two holes in it. It bolted right up w/the gasket. Then I ripped out all the EGR crap - vacumm lines, etc. I dont have a custom chip/modified ECU either. No problems here. No real seat of your pants feel in power gain, but it does assist w/working in the engine bay. Very easy to remove all the stuff. You will need a few rubber caps to cap off a few vacumm lines - got mine from AutoZone, like a dozen for $2 or something like that. Really cheap. Im in Kansas, we have no emission laws either. Just try not to rip stuff up or break stuff, just incase you have to use it again later.
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
