  • 1994 - 1995 Specific Tech
EGR removal question,.
  • Thread starter Thread starter The Hitman
  • Start date Start date May 18, 2004
The Hitman
2,541
Orlando, FL
May 18, 2004
  • May 18, 2004
How can I plug the EGR and get rid of that pesky 332 Code popping up?
The Insufficiant EGR flow code..
Thanks.
H
HRT11
122
Plattsburgh, NY
May 18, 2004
  • May 18, 2004
i used an egr delete plate and resistor
i can get you pics if youd like
95snoozer
2,572
RCR
May 18, 2004
  • May 18, 2004
what resistor?
I am swapping to a 93 cobra intake... my query is wether the fox egr will give the correct signal to the sn95 computer. the connector is the same. I am going to plug it in and see what happens
RIO5.0
6,892
N.H.
May 18, 2004
  • May 18, 2004
Funny you should mention that, on the EGR plug...When I installed my 93 Cobra I looked, and went hmmmm...That looks do-able...Never did try it...It would be sweet if the ECC accepted the signal???
R
rudeone707
1,829
Fairfield, Ca
May 19, 2004
  • May 19, 2004
i would also like to know about this resistor, my egr has been throwing that code and i want to get rid of it.
T
TMC
1,426
Chicago
May 19, 2004
  • May 19, 2004
I just kept the sensor from the EGR and taped off the plunger so that the EEC thought it was working. Then I just tucked the sensor away so and everything was fine.
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
