Electrical Mayhem
  • Thread starter Thread starter ive_escaped
  • Start date Start date Apr 22, 2009
I
ive_escaped
Moss Point, Mississippi
Apr 22, 2009
  • Apr 22, 2009
I have a 88 Gt, It was running fine, then one day on a rainy day it spun around and quit cranking. I thougt it was the inertia switch, checked, it was fine, took it off and shook it to make sure it engaged and then relocked. Still did not crank. Told my brother who has owned and repaired numerous muscle cars and mustangs. He said a bad fuel pump, dropped the tank, new pump and filter, still no go. Started checking all electrical component. Replaced ignition switch on column and fuel relay under seat, still no go. Also the starter is sticking engaged now, had to pull the battery cable.
Note that when I mist starter fluid into the intake the car will run.
How much fuel pressure should my stang have at the check valve behind the alternator (40-50#)?
How do I check to make sure the pump is running, can the pump be jumped to run at the plug by the tank?
Have been told to replace the EEC relay in the kick panel by the computer, does that make sense?
Have been told to check the fusable links in the wiring harness, where are they located?
Are there any other fuses under the hood or in the panel on the dash that may be associated with the fuel system?
The solenoid is new, have checked spark, its good.
I just checked the power to the inertia switch and I have power to that switch plug. It is my understanding that from the inertia switch the next stop power travels is to the pump, is this correct? Because I do not have power to the plug that connects to the pump, I checked with my meter. Can you jump the pump to get power with a 12v charger just to check power or will it burn up the pump if you do that. And if you can which wires do you jump to?
Any help would be greatly appreciated.....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 22, 2009
  • Apr 22, 2009
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 22-Mar-2009 to change links for electrical diagrams
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
C.) Coil
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
Sorry, the AutoZone wiring diagram links no longer work. You can navigate to the diagrams yourself via AutoZone.com | Repair Info and select the year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Continues to crank without turning the key
The starter solenoid has probably welded it's contacts together. To test this, reconnect the battery and pull the small red/blue wire off the screw post it is stuck on. If it is and ignition swich problem, the starter will stop cranking. If it is welded solenoid contacts, the starter will continue to crank. Smacking the back side of the solenoid will often unstick the contacts.
Starter solenoid wiring diagram...
Starter solenoid wiring 86-91 5.0 Mustangs with standard starter
I
ive_escaped
Apr 22, 2009
  • Apr 22, 2009
Thank you for the information, I wish I had this earlier, lol. I have replaced ignition switch, fuel relay, solenoid, starter, fuel pump, and filter. I have power to the inertia switch on the red with black stripe, used a circuit tester. Pump is not coming on. Will check the pump test at the hood hinge. Again thank you for taking the time to respond with a wealth of information.
I
ive_escaped
Apr 22, 2009
  • Apr 22, 2009
Also when I spray ether, it cranks.
I
ive_escaped
Apr 22, 2009
  • Apr 22, 2009
When I ran the test jumper to see if the pump would turn on it did
I
ive_escaped
Apr 22, 2009
  • Apr 22, 2009
I have 12v at the injectors. I have good fuel pressure when I tested the pump. One question, when i try to run the test again should the pump come on again or does the pressure have to drop below a certain point. And if all of the other items check ok does that mean that the computer is bad.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 22, 2009
  • Apr 22, 2009
This is the single most important part of the checklist:
"A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly."
Did you do the noid light test? Do you have spark when the engine is cranked?
Computers seldom fail, usually it is wiring or a sensor that has gone bad.
I
ive_escaped
Apr 23, 2009
  • Apr 23, 2009
I have power to all items, but the car will not crank at all. I have run all tests in order except where I get to a point where I have power and there are no other steps. The car just whirls over and over. I have checked to make sure it has not jumped time by bringing to tdc and checking timing marks etc... I ran the jumper to the fuel pump and it primed had good pressure @35# at schrader valve behind alternator. I checked for 12v at the injectors, had power. Have checked coil fire, spark plug wires, etc... Fixing to replace EEC relay. Have been told to replace TFI module, what is that, where is that, have been told that it is the module on the side of the distributor.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 23, 2009
  • Apr 23, 2009
Noid light test? Are you sure the injectors are firing?
Once I had a similar situation, everything seemed to be good. It turned out to be the ignition coil. It would produce spark, just not enough to make the engine run.
I
ive_escaped
Apr 23, 2009
#10
  • Apr 23, 2009
  • #10
I pulled the coil wire off the coil and its producing a very heavy blue spark 3 inches from metal ground. Instead of replacing the pick up coil and tfi (ignition control module) I found that it was cheaper to just buy a new distributor. So I am trying to stab it right now. Seems it just does not want to go. Also replaced the eec relay did not work. If all of these tests dont get me anywhere and a new distributor dont get me anywhere I assume that the only conclusion is that the ecu (brain box) is dead. Would that be correct? I cant think of anything else that would need replacing. I dont mind buying new parts, I am going to completely restore the car anyway.
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
