Electrical Problem HELP!
  • Thread starter Thread starter OL' WHITEY
  • Start date Start date Jun 4, 2008
OL' WHITEY
273
Weddington, NC
Jun 4, 2008
  • Jun 4, 2008
Hi folks,
I'm experiencing an electrical problem in my '93 GT. It happens at start-up and seems fine after I finally get the car started and it warms up a bit. What happens is that when I turn the key to crank, the tach jumps around, starter engages and turns the engine over, but the engine won't fire. After a few tries, the engine will turn over, but the tach goes crazy and doesn't reflect true rpm. If I touch the gas, the car dies. If I keep trying this six or seven times, the car will eventually fire up and run okay. After idling for a few minutes, I can shut the car off and restart with no issues. I've checked the battery connections and the battery seems okay. Any ideas?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 4, 2008
  • Jun 4, 2008
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
OL' WHITEY
273
Weddington, NC
Jun 5, 2008
  • Jun 5, 2008
Thanks, Jrichker. I'll try to run the codes and report back.
J
Jmood
169
Arkansaw
Jun 5, 2008
  • Jun 5, 2008
Ignition switch, sounds like to me.
OL' WHITEY
273
Weddington, NC
Jun 11, 2008
  • Jun 11, 2008
Okay, I have something to add to my original post. Jrichker, I haven't had time to pull the codes. I'll try to get that done tonight and report back. I was able to take the car out on the road last night for a short drive and the car began acting as I described. Eventually it died on me. I smelled something strange as I was sitting on the side of the road so I looked around the car for anything burning. Low and behold the X pipe was glowing red just behind the cats! I assume this means the car was dumping fuel (too rich)? Any more ideas on what could be happening with this. What are the symptoms of a bad MAF meter? What about that little module that screws to the side of the distributor? Could that be going bad? Any help is appreciated.
btsclan
64
Seattle, WA
Jun 11, 2008
  • Jun 11, 2008
Does the car feel sluggish? Was the pipe glowing just on one side? It could be clogged? Perhaps part of your cats broke loose and is restricting your pipe. That could explain the car dieing when you press the gas and even could be why you car takes a while to start?
Also have you check the norm, like visual inspection of you starter, all battery and starter relay ground lines?
As for pulling codes, on my 87 stang I have never been able to get a code out of it, also there might not be any codes to pull, the ECM ODB 1 computer is super basic and doesnt store that many codes. I have had a lot of problems trying to pull codes from mine.
Good luck
HISSIN50
34
129
Jun 11, 2008
  • Jun 11, 2008
If someone can't retrieve codes, the issue is likely in the wiring. These cars are complex enough that it's nice to have self-diagnostic assistance [instead of guessing].
Cats generally don't go bad on their own - an issue upstream causes them to go bad. Fix the underlying issue so you don't cook new cats [if you replace your existing ones].
You can use a vacuum gauge to get an idea about an exhaust restriction but that alone is not your issue. You noted your tach acting up, it running better as a function of operating time, and other unrelated items.
Good luck getting those codes.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Mindseye007
  • Aug 16, 2026
Mindseye007
