We're running the March Serpentine belt system on our 347 in our '65 coupe. This system uses a GM single wire, internally regulated alternator. Has anyone had experience modifying the harness to eliminate the regulator? If so, what are the mods?
truck90278 said:We're running the March Serpentine belt system on our 347 in our '65 coupe. This system uses a GM single wire, internally regulated alternator. Has anyone had experience modifying the harness to eliminate the regulator? If so, what are the mods?
stangkid88 said:I actually just put in a one wire alt. last weekend. I unscrewed the voltage regulator and just clipped the wires. I did the same for the old alternator wiring harness. I may figure out how to remove the wires altogether, but for now I just covered the ends in electrical tape.
meganjoe said:i put a power master in my 68 a few years ago and had to put a resistor ( maybe it was a diode?) at the regulator...the instructions came with the alternator...i believe it was so the amp guage still worked...
XXBULLETSXX said:Did you have to make any additional changes to the wiring in the car (beyond removing the external regulator wires) to avoid problems with that large amp alternater?
I just bought my 100 amp 1 wire alternator today and want to make the change ASAP. I'm really excited, and looking forward to getting rid of my charging problems!
