  • SN95 4.6L Mustang Tech
engine idle problem..need help
  • Thread starter Thread starter whitefox25
  • Start date Start date Feb 23, 2009
W
whitefox25
  • Feb 23, 2009
i have a 98 GT which started to run high revs while normal driving. additionally when i come to a halt the engine revs and the RPM is stuck at 2000 . when driving occasionally the car revs up all by itself as if it has a mind of its own. please help.
evil281
276
Arizona
Feb 23, 2009
  • Feb 23, 2009
maybe the throttle is getting stuck open, check ur TB
NO BRAKES
129
Avon Lake, Ohio
Feb 23, 2009
  • Feb 23, 2009
check your IAC valve, mass air, and like said before your tb
Ogre
120
NC
Feb 24, 2009
  • Feb 24, 2009
Yep, IAC. I see R&R in your future.
D
Dragstr05
643
Stafford VA
Feb 25, 2009
  • Feb 25, 2009
Our IAC's are famous for going bad, but usually they have problems with stalling. Cleaning the IAC and T/B would be a good start; its free. Pull the IAC off and clean it out real good and be sure to use a pick or small screwdriver to remove any large amounts of carbon. Worked for me once, but didnt last long.
Ogre
120
NC
Feb 28, 2009
  • Feb 28, 2009
Don't know if it's true or not, but I've heard stay away from AZ IAC and TPS. Anyone have any comments on that.
superstang46
21
Fernandina Beach, Fl.
Feb 28, 2009
  • Feb 28, 2009
Sounds like classic IAC. when mine went I got it from NAPA and never had another problem as long as I owned the car 3+ years.
R.J.
813
Warwick, Rhode Island
Feb 28, 2009
  • Feb 28, 2009
Replace your IAC (don't buy it from Auto Zone) then reset your idle with this procedure:
You will probably get a million different responses on how to do this. This is how I have done it and it works for me. And I've done it a lot.
1. Disconnect the negative terminal to your battery and turn on your headlights for about 10 minutes(there's a lot of speculation as to how long. some people will even say to disconnect the positive terminal and some people will say to leave it disconnected over night.)
2. Disconnect the wiring harness connector to the IAC
3. Turn off headlights and reconnect battery. DO NOT TOUCH THE GAS PEDAL!!
4. DO NOT TOUCH THE GAS PEDAL!! Try to start the car. If the car won't start adjust the set screw on the throttle body a 1/4 - 1/2 turn and try again. Repeat until the car will stay running. It will run rough but that is what you want.
5. Let the car sit and idle (DO NOT TOUCH THE GAS PEDAL!!!) until the car reaches operating temperature.
6. DO NOT TOUCH THE GAS PEDAL!!! Step 5 allows the computer to relearn idle settings. It's pretty cool when you follow my procedure because you can actually hear and feel the car figuring out the proper idle settings. It will go from idling rough to idling smooth as it warms up. Once the car is warmed up verify that the car is idling at around 700rpm. If the car is not idling where you want it, adjust the screw until it hits ~700rpm and then let is sit maybe another 10 minutes DO NOT TOUCH THE GAS PEDAL!!!
Turn the car off. Reattach IAC wiring harness. Now remember we adjusted the set screw on the throttle body. That means that the voltage reading from the TPS sensor has changed. It should read between .96 and .99 volts. Anything outside of that range will cause all sorts of issues including misfires and rough idle.
7. You will have to back probe the TPS connector. With the connector attached to the TPS stick a paper clip into the rubber boot on the connector where the top and middle wires go into the connector. The rubber is very flexible the paper clip will slide in between the rubber and the wire.
8. Set your multimeter to volts. Turn ignition to ON. Then place your multimeter leads on the metal pins. If it comes up as a negative that is okay as long as you are -.96 to -.99. If you get this reading then great you are done and hopefully your issues are gone. If not proceed to step 9
9. This is where and extra pair of hands come in handy. Using a large screw driver you will need to loosen the bolts that hold the TPS. DO NOT USE A SCREWDRIVER THAT IS TOO SMALL BECAUSE YOU WILL STRIP THE BOLTS. They probably will be really tight so you have to really lean on the screwdriver and use some finesse.
10. Once the bolts are loose you will need to move the TPS up or down and continue to read the voltage. Once you get it to the desired setting you can retighten the bolts. What I do is I find .97 and then as carefully as possible I tighten the TPS down. what will happen is the voltage will change usually to .96 or .98 but that it okay. Once you are done with this manually open the throttle body a few times and close it then reread the voltage and make sure it is still within our desired range.
11. Depending upon how loose your set screw was you might want to cover it in RTV to hold your setting. At this point you have CORRECTLY reset you idle.
Flghtmstr1
572
Springfield, PA
Feb 28, 2009
  • Feb 28, 2009
The newer cars (96+ I believe) do not require any adjustments to the idle. Just pull the negative terminal off the battery for a while to reset the ECU, and it will relearn just fine on its own.
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
