Engine running rich
  • Thread starter Thread starter Begizzle
  • Start date Start date Apr 6, 2008
Begizzle
49
  • Apr 6, 2008
I have a 93 lx. stock bottom end h/c/i with supporting mods. I am running base fuel psi at 40 with 30 lb injectors and calibrated maf. It has all new sensors including o2 sensors. Base timing at 16. The car starts up and runs great from a cold start. It will idle smoothly at 900 rpms. Once the engine is up to operating temps it starts smoking badly. The smoke is like a bluish tinted smoke but it definately smells like fuel and it burns your eyes. The car still idles smoothly and runs great. The shortblock was just rebuilt and has 0 miles. Motor has 45 psi oil pressure at idle.
What could be the problem? I was thinking o2 sensors since it only happens once the engine is warm. Also, I have a holley fuel psi regulator and the pressure drops to zero once the car is shut off. Is that normal?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 15, 2008
  • Apr 15, 2008
could it be IAT inlet air temp? Almost sound like it is going into choke mode. If it was rich from get go I would suspect ECT sensor. Engine coolant temp. Still could be an issue.
tb9050lx
155
ct
Apr 16, 2008
  • Apr 16, 2008
i think your injecters are too big for this setup 24 lbs might be a tad better!!!
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
