Engine still ticking, me still banging my head.
  • Thread starter Thread starter Hydrocarbon
  • Start date Start date Jun 29, 2004
First Prev 2 of 2
GREG91GT
207
MISSOURI
Jul 2, 2004
#21
  • Jul 2, 2004
  • #21
you dont think its any thing doing it around the converter or fly wheel do you
H
Hydrocarbon
160
Medford Oregon
Jul 2, 2004
#22
  • Jul 2, 2004
  • #22
The valve train is completely stock. I checked a few pushrods the last time I had the valve cover off and made sure they were straight. I'm going to check all of them next time.
If it was a problem with the flex plate, wouldn't the tick be a lot faster? When I use my stethoscope I can hear it spinning but there's no ticking. I'll pull the inspection cover off tomorrow just for fun.
Keep the replies coming. I want to make a list of things to check when I pull the valve covers off again.
GREG91GT
207
MISSOURI
Jul 2, 2004
#23
  • Jul 2, 2004
  • #23
is there any way you could have a bad plug and its grounding or arcing off of the head check at night time or with lights off
H
Hydrocarbon
160
Medford Oregon
Jul 2, 2004
#24
  • Jul 2, 2004
  • #24
It sounds like a plug wire arching, but I don't see it aching anywhere. All my NGK plugs are tight, and look good.
saleenx029
117
Cincinnati, Ohio
Jul 2, 2004
#25
  • Jul 2, 2004
  • #25
To help with arcing you should put protective boots around the wires at the plug, this fixed my wire arcing, and also make sure the wires are routed seperate from each other, not all bunched together, even Taylors will arc if they are bunched. Just some ideas
five_o_stang
92
Georgia
Jul 2, 2004
#26
  • Jul 2, 2004
  • #26
I had a tick coming from my car when I had a sparkplug unseat itself...i was looking all over for the source and just happend to glance at the plug and see it rocking back and forth throught the cycles...tightened it up...click was gone.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jul 2, 2004
#27
  • Jul 2, 2004
  • #27
Try relieving the fuel pressure than disconnecting the pump.
Disconnect the igniton and take the spark plugs out and have a friend crank it over and listen if the tick is there when the motor is not runing.
First Prev 2 of 2
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
