  • SN95 4.6L Mustang Tech
Engine Swap SOHC to DOHC
  • Thread starter Thread starter kirk69
  • Start date Start date Apr 13, 2009
K
kirk69
11
  • Apr 13, 2009
I have a 2000 GT and a wrecked 2001 Cobra. I plan on swapping the engine out of the Cobra to my GT. What parts do I need from the Cobra to complete the swap?
squeak93
2,335
412
164
Joplin, Missouri
Apr 13, 2009
  • Apr 13, 2009
Engine, wire harness, puter, and maybe trans (depends if u want t-45 or 3650.)
Anyway. Since you have a donor car, its actually a pretty simple swap.
K
kirk69
11
  • Apr 13, 2009
Do I need the radiator, power steering pump, a/c, or PATS controller? How about the steering column? I have a automatic right now.
squeak93
2,335
412
164
Joplin, Missouri
Apr 13, 2009
  • Apr 13, 2009
You will need the pats for what ever puter you use. If you stick auto, then use the gt puter and have it reflashed.
The power steering and stuff should all be the same, double check that though as I'm not 100% sure. Rad and fan should also be the same.
K
kirk69
11
  • Apr 13, 2009
I'm confused on the whole PATS thing? Can someone walk me thru it? Do I need all the PATS devices off the Cobra to make the car run? I got a little lost there!
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
