  • SN95 4.6L Mustang Tech
exhaust leak
  • Thread starter Thread starter ooraceredgt
  • Start date Start date Dec 30, 2006
ooraceredgt
204
  • Dec 30, 2006
cant figure out where exhaust leak is coming from. checked all joints on exhaust and even had smoke test done. is it possible for the manifold gasket needs to be checked/replaced. i dont know how long a stock gasket will last.
Jsun3701
124
Virginia
Dec 30, 2006
  • Dec 30, 2006
Why do you think you have a leak?
ZIncGTSTANG
34
  • Dec 30, 2006
Check your EGR pipe. Check for tight connections and also check along the pipe to see if its cracked. They can crack very easily. My brother had an exhaust leak and it turned out to be a cracked EGR pipe.
the98stang
2,408
Clovis, CA
Dec 30, 2006
  • Dec 30, 2006
Did you run seafoam through it? That smoke is very white and you could spot the leak easily....
ooraceredgt
204
  • Dec 30, 2006
i can here it "spitting"
Saleen4971
664
Setauket, LI
Jan 1, 2007
  • Jan 1, 2007
check the pro-chamber to manifolf flange. if its leakign form there replace the factory studs with normal ones (with no shoulder) or bolts. mine leaked right there, and the flange bottomed out on the shoulder - so i had to put some bolts in (didnt have studs on hand)
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jan 1, 2007
  • Jan 1, 2007
spray soapy water on the joints, and look for bubbles
Superhereaux
chicks make me feel inadequate
538
South Texas
Jan 1, 2007
  • Jan 1, 2007
did you use different studs when you installed the pro-chamber?
also did you use the stock copper gasket on the pass. side or the paper piece mac sends you?
H
HercFE
55
Sacramento
Jan 1, 2007
  • Jan 1, 2007
I would check your plugs, I thought I had a exhaust leak for a while and it ended up being a loose plug that eventually got spit out, check your plugs!!!!!!
ooraceredgt
204
#10
  • Jan 1, 2007
  • #10
i used a new gasket from ford and the studs were replaced when i installed the prochamber. i'll get some seafoam tomorrow and double check for any smoke. also i'll check the plugs. thanks
steveb24
555
wilmington, DE
Jan 1, 2007
#11
  • Jan 1, 2007
  • #11
plugs plugs plugs! dont make the same mistakes as some of us!!
Superhereaux
538
South Texas
Jan 2, 2007
#12
  • Jan 2, 2007
  • #12
replacement stock studs or the napa stud kit?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 3, 2007
#13
  • Jan 3, 2007
  • #13
That works for about all of about 45-seconds until the exhaust temperatures burn off the soapy water......so you'd better get your ass underneath the car quick.
ooraceredgt
204
#14
  • Jan 21, 2007
  • #14
thanks guys for your help!!! it turned out to be a plug and I can't thank you guys enough for suggesting this!!!!
the98stang
2,408
Clovis, CA
Jan 22, 2007
#15
  • Jan 22, 2007
  • #15
Damn I hope you caught it before it did any damage....
00BlkStangGT
46
Pleasanton, Ca
Jan 22, 2007
#16
  • Jan 22, 2007
  • #16
Can someone describe what the sound is like if a plug is loose. I suspect I have a leak, but it doesn't sound the same as the last exhaust leak I had.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 22, 2007
#17
  • Jan 22, 2007
  • #17
It'll sound like a progressivly loud "ticking" noise, similar to a leaky header gasket.
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
