Exhaust Pointers?
  • Thread starter Thread starter 87WhiteStang1
  • Start date Start date Jun 17, 2008
87WhiteStang1
182
  • Jun 17, 2008
My new exhaust system is on the way and i am going to put it on my 87 GT. the system is a Pypes off road x pipe and 2.5" muffler system. I'm taking the stock off. never done anything with the exhaust on this car yet. Any pointers?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 17, 2008
  • Jun 17, 2008
The x-pipe should be pretty easy, but a second pair of hands to keep the tailpipes aligned is always helpful. You'll need to maneuver them up and over the axle and it can be a big PITA, but it is doable. Just take your time and you'll be alright.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 17, 2008
  • Jun 17, 2008
Depending on how clean the car is, hopefully you won't snap the header/h-pipe bolts/studs. That will suck. Other than that, everything bolts up great. As stated above, a friend will be nice to help you hold the tails in place.
A tip I would like to share is...when bolting the mufflers to the H-pipe, I usually place a 1/2" extension between the lower torque box and the muffler. This way the muffler won't twist when you are tightening the bolts. If it twists, it hits the torque boxes and the noise is very loud in the car. I do the same thing while bolts the tail pipes to the muffler. I place the 1/2" extension between the tailpipe hump and the frame rail. This gives you enough room so they won't hit. (Some mufflers are different sizes, so I had to do this with Flows and MAC's, but my Dyno Max Super Turbos had more room, where I didn't need to space them out.)
Another tip....Don't tighten the bolts super tight until all the bolts are in and snug. Get your gaps good between the exhaust and body/frame, then tighten incrumentally. That way nothing will get outta line. Works everytim for me.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
