  • SN95 4.6L Mustang Tech
exhaust Question
  • Thread starter Thread starter 01stangt
  • Start date Start date Nov 9, 2004
01stangt
  • Nov 9, 2004
Im lloking at getting an xpipe, I have a good set of flows on the car now question is should I delete the cats , and would you recomend bbk or bassani thanks
Steve777
208
Pittsburgh, PA
Nov 9, 2004
  • Nov 9, 2004
If you wanna go catless, thats up to you - and whether or not you have emissions. But as far as the x pipe goes, bassani and bbk are the last brands I would recommend to go with the Flowmasters. I've heard a lot of people complain about rasp with these brands. I would recommend SLP if you are going to go with the catted X, or Mustangtuning if you are going to go O/R. Both are great quality, and sound amazing with flowmasters.
01stangt
  • Nov 9, 2004
Here in michigan we have no emisions so Ill probably get rid of the cats.
Ill look into the pipes you recomended. thanks for the info
Steve777
208
Pittsburgh, PA
Nov 9, 2004
  • Nov 9, 2004
no prob. If you are wondering why, take a look at pics of the design of bbk or bassani, then compare it to some others. They use a different X junction and I just don't think they give the clean, smooth X pipe howl that people want. www.mustangtuning.com has some good x pipes that I mentioned
good luck
Stanger35thGT
Houston, TX
Nov 9, 2004
  • Nov 9, 2004
whatever you do, do NOT put a BBK pipe on your car...
BBK is the worst pipe ive ever heard...it tends to sound like you have marbles underneath your car that are rattling...
check out the MustangTuning O/R X...ive heard good things about it...and its affordable...
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Grown Man Crying
  • Potomus Pete
  • Sep 8, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
LILCBRA
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
