exhaust setup question...
  • Thread starter Thread starter genericstang
  • Start date Start date Jun 4, 2006
G
genericstang
120
Marietta. GA
Jun 4, 2006
  • Jun 4, 2006
i rencently installed FRPP headers, BBK o/r h-pipe and a magnaflow catback exhaust. the sound is a lot better then stock exhaust mani's, stock h, and flows.
BUT....
the BBK H-pipe sags a little on the passenger side and is too low for my liking(very very very slow over speed bumps, driveways, etc.) i would say i have maybe 4-5 inches clearance max. everything is mounted up correctly and in the proper hangers etc.
has anyone had any problems with this before, any possible solutions? thanks in advance
G
genericstang
120
Marietta. GA
Jun 4, 2006
  • Jun 4, 2006
bump
kornchild4life
46
islip, ny
Jun 5, 2006
  • Jun 5, 2006
I have no complains or problems with my BBK H-pipe, doesnt hang out any lower then my stock H and I'm running flowtech shorties to the H-pipe and to flowmaster
G
genericstang
120
Marietta. GA
Jun 5, 2006
  • Jun 5, 2006
hmmm....anyone else?
thanks
DeadLifter
183
Portland, IN
Jun 5, 2006
  • Jun 5, 2006
Loosen the H-pipe on both ends and put a floor jack under the middle set it where you want it and tighten it. Might have to realign your tailpipes afterwards.
G
genericstang
120
Marietta. GA
Jun 6, 2006
  • Jun 6, 2006
yeah i was thinking about doing that. thanks for your help.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jun 6, 2006
  • Jun 6, 2006
Get a floor jack and put it right under your H. Loosen the flange at the headers and at the muffler/h section, then jack it up to where it's just about hitting the floor, then tighten it all back up.
G
genericstang
120
Marietta. GA
Jun 8, 2006
  • Jun 8, 2006
thanks for everyone's help. ill see if this works.
M
mrf0rd
64
Kent, WA
Jun 23, 2006
  • Jun 23, 2006
Sorry about the thread jacking but I have a question about my BBK H-pipe.
What is the small 90 degree pipe fitting that right behind the hangars? I blocked off the O2 sensor ports but I'm not sure what the other is for.
Your help is greatly appreciated.
Blk91stang
607
North Brunswick, NJ
Jun 23, 2006
#10
  • Jun 23, 2006
  • #10
I had the same problem until I replaced my tranny and crossmember bushings with energy polyurethane, than my exhaust magically rose about an inch. These should be changed either way as I'm sure your stock ones are shot.
DeadLifter
183
Portland, IN
Jun 23, 2006
#11
  • Jun 23, 2006
  • #11
"What is the small 90 degree pipe fitting that right behind the hangars? I blocked off the O2 sensor ports but I'm not sure what the other is for."
I believe that's a hookup for a hose that runs off the smog pump or some smog related part.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
  • Gulftown980x
  • Jul 29, 2026
squeak93
