Exhaust Woes
fox-gt
204
TN
I replaced the headers, catback and h-pipe on my car about one year ago. It has been one problem after another. Things never lined up right, stuff rubbed, vibrated, leaks everywhere, etc. Headers hitting the steering arm, gaskets blowing out after I installed them, the local tire shop breaking the h-pipe flange driving the car off the rack, numerous trips to the local muffler shop getting it aligned, etc.
The guy who rebuilt my engine lined everything up, and for about 2 weeks the car sounded incredible. Now it is leaking again between the h-pipe and catback. It is also vibrating (around the mufflers) really bad everytime I press the throttle hard.. It feels like the H-pipe is vibrating the shifter and floor pans. I don't know what else to do. I am so tired of dealing with it. Should I weld everything up (tail pipes, h-pipe to catback)? I never thought something could be such a pain in the butt. Its frustrating to spend so much money only to have as many problems with it as I have had.
The headers are fixed, new motor mounts, a hammer and locking bolts fixed them.
I'm open to any suggestions on how I should address this problem.
The vibration under the car may be your mufflers up against the frame.Are the mufflers welded or clamped?The only bolts should be the h-pipe to the headers,and the mid pipes to the h-pipe.Everything else should be welded.Another way to seal your headers better,is,if your flange is a thick one piece unit on your headers,cut the flange between each pipe and then each exhaust port can seal better without the flange warping due to heat.A reputable exhaust shop should be able to fix your leaks for good.That's their job.I wouldn't weld the h-pipe to anything,if you had to pull it for tranny work or anything else,it would be a LOT of trouble getting the exhaust down,and back up.My BBK's were hitting my steering shaft also.Big tubes.I pulled the header the other day and gave in a few little taps with the hammer (gently,because I didn't want to mess up the flow,just wanted to bend it enought that it doesn't hit anything.Nice and easy).It was easy to see the spot due to the scratches from rubbing.I didn't want the steering shaft to eventually rub a hole through the header.Check under the car for spots on the chassis to see if the pipes or mufflers are hitting anything.If it's an all the time thing,you'll probably see bare metal where the rubbing has occurred.In my experience,it's usually the mufflers hitting at one corner or the other.Good luck.
I swap exhausts all the time due to emissions stuff and haven't had any leaks yet. Don't know if you did it or not, but when i change the exhaust on my car you need to bolt the exhaust up losely, get it lined up, then using a jack/jack up the h-pipe, then tighten the exhaust. That's the way i have always done it and i haven't yet had a leak.
Thanks
Thanks
Yeah same with me also. I jack the H pipe up until its tucked under the car and not hanging down then tighten everything up good. Header gaskets are a pain also, my advice is to get copper gaskets and locking header bolts like Stage 8 sells. Install the copper gaskets and Stage 8 bolts (without the locks), drive the car a while till things get good and hot, let everything cool then retighten the header bolts then install the locks.
I guess my concern is what caused it to start leaking / vibration after the engine builder straightened everything out in the first place, and will it do it again.
GearHd6 said:
Header leaks start from the bolts loosening up and then the gasket blows out. You've got to keep then tight and the copper gasket holds up MUCH better than normal gaskets.
Headers are fine, after they leaked the 1st time I used stage 8 locking bolts, no problems since.
I will try jacking the h-pipe up and adjusting.
Thanks everyone.
