F-cam
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Nov 13, 2006
1 of 2 Next Last
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 13, 2006
  • Nov 13, 2006
How much lift does an F-cam have and would it make the engine real lopey? I went and looked at a car today and the guy said it had an F-cam. The car was setup for a supercharger but the charger is gone everything esle for the charger is still there. The car Idled like crap and it sounded like the rocker arms were hitting the Valve covers.
blkcobra50
209
  • Nov 13, 2006
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 226
Duration at 050 inch Lift: 226 int./226 exh.
Advertised Intake Duration: 288
Advertised Exhaust Duration: 288
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Lobe Separation (degrees): 109
RsStanG1987
569
9
79
Dupont PA
Nov 13, 2006
  • Nov 13, 2006
So this cam should be pretty lopey correct?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 13, 2006
  • Nov 13, 2006
Yes, it's quite lopey. The computer probably didn't care much for it with a 109° lobe separation, unless it was tuned.
RsStanG1987
569
9
79
Dupont PA
Nov 13, 2006
  • Nov 13, 2006
Im still iffy about if this car even has a cam.. There are no vacum lines hooked to anything and the guy says the motor was just rebuilt. But the car sounds like complete ass and it was banged in the front with a shotty repair job. Im probabbly going to walk on this deal.
Auto Reverse
265
Buffalo, NY
Nov 13, 2006
  • Nov 13, 2006
I have this cam, I like it...works great with nitrous.
9
90bluegt
592
  • Nov 13, 2006
With this cam, power doesn't come on till about 3k RPM's. I used to have it, power is great after 3k rpms though.
FSTRDNU
76
  • Nov 14, 2006
thats not a very good blower cam, with the 109* ls
with that, you literaly blow your boost right out the exhuast, with all that overlap.
millhouse
1,985
Simpsonville, SC
Nov 14, 2006
  • Nov 14, 2006
Actually…it's original intention was a forced induction cam. It works well on both super and turbo apps.
RsStanG1987
569
9
79
Dupont PA
Nov 14, 2006
#10
  • Nov 14, 2006
  • #10
I went and looked at the car again the guy wont budge on his price. Im sure i can make money off the vortech stuff it has but i dont wanna chance it. It was smashed before too. Thanks for the help guys..
M
ms93gt
239
Bayville, NJ
Nov 14, 2006
#11
  • Nov 14, 2006
  • #11
the lobe seperation is 114*. summit is dumb.
Jozey
127
Tucson,AZ
Nov 14, 2006
#12
  • Nov 14, 2006
  • #12
thats what i thought.i have that cam in my turbo motor.works awsome.my cam card says 114* of lobe seperation
bubba-dough
1,044
Indiana
Nov 15, 2006
#13
  • Nov 15, 2006
  • #13
Yeah the F cam was Ford's blower cam. My pal had it in his 302 hci and paxton. It was quite lopey and made good power.
XStanger
383
#14
  • Nov 15, 2006
  • #14
Really? I thought this was a cam that was between the E and X specifically for Power added cars.
It made great power with my B Trim back in the day.
Jozey
127
Tucson,AZ
Nov 15, 2006
#15
  • Nov 15, 2006
  • #15
then why are people putting down awsome #'s?ive seen some stangs going into the 9's with that cam.
Dr. Wu 2000
554
Eastern, Pa.
Nov 16, 2006
#16
  • Nov 16, 2006
  • #16
I just picked up a 93', actually a member of this boards ride and it has a F-Cam with Trick Flow Track Heat intake and Twisted Wedge heads with a mild port job...is this a good cam for this set-up??? He originally said it was going to be blown but sold it before he did the blower, should I stay with this cam or go to another one??? It has a great lope but seems to have a miss and it is not chipped or tuned, just timeing and fuel pressure set. Just curious if this is too much cam for a N/A motor..motor is brand new (9K miles) 302 crate motor w/ 1.6 roller rockers. I can give extensive list of mods if needed. Thanx.
Jozey
127
Tucson,AZ
Nov 16, 2006
#17
  • Nov 16, 2006
  • #17
you will be fine
aleborjas
610
#18
  • Nov 17, 2006
  • #18
that cam can't be a blower cam first is simetric same lift a dration in both sides and second lobe separation thats a N/A cam and i had one and i read the card and it sais 109º and i put it on my 306 and did not like it then i whent with comp cams and the difference was laki 50 HP more something like that was a lot of difference!
millhouse
1,985
Simpsonville, SC
Nov 17, 2006
#19
  • Nov 17, 2006
  • #19
If you research on what a good off the shelf blower cam is…and you'll find the f303 is a-top most of the lists.
Duration = 226/226
Lift = .512"/.512"
LSA = 114* (109*intake/119*exhaust)
And finally, you cant go spouting off hp claims on what you felt. Chances are…the power difference was quit comparable. The big reason you felt less h/p is the f-cam is a mid-high rpm cam. To take advantage of it you have to either have forced induction…or give it more rpm.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 17, 2006
#20
  • Nov 17, 2006
  • #20
People can argue the cam all day...some will love it, other will have crashed and burned with it..like everything in life. Real question is....what does the car HAVE vs...what the owner says it has? Can he provide any documents to confirm the parts he tells you it has? Guys love to list off items to generate interest...words like 'cam' and 'ported' when unfortunately too often the intake bolts have never even been out. Go in questioning everything and decide if the car 'as is' is really something you want...
1 of 2 Next Last
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Fuel Idle Chops With No Cam
  • FiveOhGabe
  • Oct 30, 2024
Fox 5.0 Mustang Tech Oct 30, 2024
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
