Fires but doesn't start
  • Thread starter Thread starter buz19
  • Start date Start date Jul 14, 2008
buz19
9
Ontario, Canada
Jul 14, 2008
  • Jul 14, 2008
I've got a 67 289 that has been working great until last week when it just stopped going down the road. It had done about 3 times before but always re-started. This time I could not get the engine re-started. The engine will fire when ask to start but when I let go of the key it dies right away. No sputtering like it's not getting gas , so I've ruled out a gas problem. I'm tthinking it's a ignition problem. Does anyone know where I should start lokking???
P
palerider94
573
  • Jul 14, 2008
Sounds like it could be the Ballast resistor. I had a similiar problem. There is a wire going to the coil that reduces the voltage from 12v to 6v. If resistor burns out - you get problem you mentioned - fires with key in on position but as soon as you let go of the key it dies - (no electic to coil). Easy to test, jump a wire from battery to coil and fire it up - if it stays running it's the balast resistor wire. Don't leave it running that way for too long or you will fry coil. Expecting only 6 volts. Good luck. Took me a while to figure this one out - when it happened to me.
carefact0rzero
49
columbia, sc
Jul 14, 2008
  • Jul 14, 2008
also check to make sure that any of the wires coming from the back of your ignition switch haven't slipped off somehow. just happened to me this past weekend.
buz19
9
Ontario, Canada
Aug 10, 2008
  • Aug 10, 2008
Turns out it was the starter solenoid creating a direct short to ground. replaced solenoid and no more problems. Of course that was after I replace the ignition switch and jumpered the resistor wire to the coil!!!!
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 3:55 AM
manicmechanic007
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
