Firing order
  • Thread starter Thread starter lxman
  • Start date Start date Nov 23, 2010
First Prev 2 of 2
lxman
279
Avondale, AZ
Nov 27, 2010
#21
  • Nov 27, 2010
  • #21
Well I had it parked in the garage overnight with a heater on. I tried to start it and the starter is still doing the fast clicking thing. Could my starter have just gone bad? Or is there a way to check it without pulling it off, or should i just pull it and get another one from the junkyard? Please Help!!!
BlackGT89
774
Huntsville, AL
Nov 27, 2010
#22
  • Nov 27, 2010
  • #22
Check the battery voltage with a voltmeter and see if you have 12V. Pick up one of those battery terminal cleaner tools and clean the cable ends and posts really good. If you have a bat. charger leave it on for a few hours and charge the battery. Sometimes a (small) shot of starting fluid (ether) will get things moving as well.
lxman
279
Avondale, AZ
Nov 27, 2010
#23
  • Nov 27, 2010
  • #23
Thanks i will definitley give that a try. I will hook my battery charger up tonight and try all that tomorrow. Thanks again!
BlackGT89
774
Huntsville, AL
Nov 28, 2010
#24
  • Nov 28, 2010
  • #24
If that doesn't do it, try giving the solenoid on the fender well a tap with the handle of a screw driver or something. If the fast clicking continues you might need a new solenoid. Starters usually act up when they are hot, but you could pull it off and have it tested if you think it's bad. But that a lot of work unless you have tried everything else.
lxman
279
Avondale, AZ
Nov 29, 2010
#25
  • Nov 29, 2010
  • #25
Well just to update everyone I found out what is wrong with my starter. I pulled it off and first i found that it was stuck so thats why it wouldn't engage. Then I found that the gear engages the flywheel is all chewed up and bad. So, I have to get a new starter!
BlackGT89
774
Huntsville, AL
Nov 29, 2010
#26
  • Nov 29, 2010
  • #26
Wow, you mean the started had actually seized up ? That's strange. I hope the teeth on your flywheel are okay as well. Keep us posted.
stang&2Birds
2,091
New England. :-) CT/MA
Nov 30, 2010
#27
  • Nov 30, 2010
  • #27
As mentioned, make sure that the teeth on the flywheel are not ruined/broken. The gear on the starter is suppose to wear/give first (softer metal). But, sometimes, it doesn't always go like that.
The gear on the starter may have gotten chewed up because of a weak battery.
Make sure you have oil that is 10W-somethingW, and not 30W-50W.
If it's easy, keep the battery warm inside. That will help with starting.
A cold engine is also much harder to start. When a cold engine that's added to a battery that's ~50% down on it's max cranking ability, that could be too much to ask for an old/weak battery.
That's why they have battery heaters, along with block heaters for the extreme cold.
Also, you can try to put a battery charger on the battery for 3-5 hours before trying to start the engine. That will help top off the battery charge, and also "warm the battery up a very little" because it's charging.
Good Luck!
lxman
279
Avondale, AZ
Nov 30, 2010
#28
  • Nov 30, 2010
  • #28
From what I can see the flywheel seems to be ok when i looked at it. Yeah the starter would turn because the gear was worn down so much on the one side it was snagging.
First Prev 2 of 2
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
