Flickering Lights
  • Thread starter Thread starter Dean85GT
  • Start date Start date Dec 16, 2006
Dean85GT
502
Thorold, Ontario, Canada
Dec 16, 2006
  • Dec 16, 2006
After I installed my motor I developed a problem with my lights going dim and bright when I am driving at night. The car never used to do this even with 2 amps and a decent stereo. When I was driving the car in November I didnt have the stereo installed, and the lights would flicker at night. Can this be somehow related to the grounds? I doubt its the alternator because it was fine before I pulled the motor.
When I reinstalled the motor I didnt use the stock ground straps. I'm running a 4 gauge wire off the negative terminal to the engine block and then a 4 gauge wire from the engine block (on a different spot) to the chassis. I noticed the chassis ground started to corrode a bit because I ground it down to bare metal. I think that maybe I didnt make the contact service clean enough on the block. Would this cause anything to do with the lights? I dont have any problems with a dying battery or anything either, and the grounds on the lights are all fine.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Dec 16, 2006
  • Dec 16, 2006
If the lights are flickering off and on, it might have to do with you headlight switch or your multi-function switch. I had a similar problem and it turned out to be my multi-function switch. If they are just getting dim and not actually going off I would think it would have to do with the grounds. Check the headlight ground connections to see if they are clean of corrosion and paint.
Dean85GT
502
Dec 16, 2006
  • Dec 16, 2006
I forgot to mention that my interior lights do it as well...Someone else suggested checking the voltage regulator
HISSIN50
34
129
Dec 16, 2006
  • Dec 16, 2006
If your stang has a fender-mount solenoid like an aero fox, ensure the connections are super tight and clean. That's where primary power to the circuits you mentioned comes from.
Good luck.
kendoo130
244
Huntington Station N.Y.
Dec 17, 2006
  • Dec 17, 2006
You more than likely missed hooking back a ground wire. Just make sure the there is a ground running from the battery to the body. On the factory negative battery terminal this is usually a small wire (about an 8 guage).
Dean85GT
502
Dec 17, 2006
  • Dec 17, 2006
I do not currently have a ground directly from the battery to the body....Maybe that is something to try. Can anything bad happen with too many ground wires?
Dark Knight
2,578
Chandler, Az.
Dec 17, 2006
  • Dec 17, 2006
Had the same prob when the block to firewall ground had a bad connection, might double check that.
Dean85GT
502
Dec 17, 2006
  • Dec 17, 2006
Hollllllllllllld on a sec. I currently only have one ground wire off the negative terminal to the block and ONE off the block to the body...Is there suppost to be two grounds off of the engine block?
Dark Knight
2,578
Chandler, Az.
Dec 17, 2006
  • Dec 17, 2006
I have a ground from the back of the intake to the firewall..
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
