Flywheel Question
  • Thread starter Thread starter 347Fastback
  • Start date Start date Feb 5, 2004
347Fastback
340
Central Coast
Feb 5, 2004
  • Feb 5, 2004
I am doing a T-5 conversion on my 65 fastback and I have a couple of questions. My car is a 4spd car and when I took the clutch and flywheel out I found out the flywheel is 11 inch instead of 10.5 or 10. Is this stock for this car??? Will it work with a late model clutch setup...????
SandSprite
332
L.A., CA
Feb 5, 2004
  • Feb 5, 2004
If the flywheel is 157tooth, it will work with the t5 bell. If it's 164tooth, it's not gonna fit (been there, done that...)- you can either get another flywheel (what i did) or use the 4sp bell and an adapter (not the best route, IMO). If going with cable or hydraulic for the clutch, you will need to use the late model bellhousing and fork. What motor is in front of this t5 currently?
347Fastback
340
Central Coast
Feb 5, 2004
  • Feb 5, 2004
Got a 302 out of a 69 Mach 1... It is coming out as soon as it warms up around here. I should get my ceramic coated longtubes in the morning... I ended up ordering the mustang steve master kit with new pedals and cable setup...
SandSprite
332
L.A., CA
Feb 6, 2004
  • Feb 6, 2004
Well once you figure out which flywheel you got, you'll be pretty close. Weather's supposed to be nice this weekend-- I'm actually plannin' a small cruise up here for Saturday. Hope your swap goes smoother than mine. Did you get a crossmember yet? I'd say if I was down your way, you could take a look at mine -- easy to make if you got a welder. I'll have to check out your car sometime.
Good Luck
347Fastback
340
Central Coast
Feb 6, 2004
  • Feb 6, 2004
Good Luck
So where are you guys getting together at. I might jump in the saleen and come check your car out....
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Saturday at 9:08 AM
SchwarzStock
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
