Font end sqeaking!
  • Thread starter Thread starter ddt4436
  • Start date Start date Jun 21, 2009
D
ddt4436
70
  • Jun 21, 2009
There is some horrible sqeaking from my front suspension on my 1991 mustang 5.0 when I go over bumps. Sounds like the whole car is coming apart at times. It only happens when I am going over speed bumps or hills. Any help?
R
RAYMOND259
56
  • Jun 21, 2009
Check your ball joint
HISSIN50
34
129
Jun 21, 2009
  • Jun 21, 2009
If it's that bad, how does it only happen while going over speedbumps?
As noted, give the front end a once over. End links like to make noise on speedbumps but they generally make a metallic clicking.
Strut bushings can make a lot of noise as the damper compresses and they deflect. Check yours.
And please let folks know what year and sort of mods your car's suspension has.
D
ddt4436
70
  • Jun 23, 2009
Yeah it's that bad and it only happens when the car is riding over bumps or rocky surfaces. I did say the car is a 1991 mustang gt. It's all stock.....everything.
backfocus
254
Little Rock, AR
Jun 23, 2009
  • Jun 23, 2009
It is probably the sway bar bushings. I had that happen on mine and I just replaced them. It could be the end links too, and I would just replace both while you are at it and have it apart.
You could spray some WD on them and see if it helps at all, if you are still unsure, but it is hard to get it inside the sway bar bushings. That is not a fix just a way to find out what it is, you will need to replace them. You can buy bushings that you can grease as well.
Vinnietbird
584
  • Jun 23, 2009
Mine did the same thing,it was the ball joints and the a-frame bushings.
D
ddt4436
70
  • Jun 23, 2009
Thanks guys for all the help. I will def take a look at all those parts you guys mentioned. Thanks alot!
D
ddt4436
70
  • Jun 25, 2009
Any more ideas ?
HISSIN50
34
129
Jun 25, 2009
  • Jun 25, 2009
What did you find when you took a look at it?
MuDDuQ
32
#10
  • Jun 25, 2009
  • #10
I had the same thing a few years ago it was the sway bar bushings it was horrible but it only cost me about 20 or 30 bux to change the bushings and its pretty easy to do
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • Mindseye007
  • Aug 16, 2026
Mindseye007
