haha. im back.
grab a test light and probe fuses in the fusebox. find one that is key-on hot only, and splice into it, on the dead side of the fuse.
good luck. (i think i have used fuse 9 before - HVAC IIRC).
EDIT: what Grn said should work too - he posted while i was messing around.
Whats Oil Pressure supposed to be with a supercharged engine? Im not sure if that makes a difference but just wondering. Whats a good PSI at Idle? Thanks
1991, as long as the integrity of the ignition wire was not compromised (you did a nice proper soldered splice, etc), it should be fine. i think many folks go the route you do (one of the yellow wires under the column is the normal point of tapping).
