Electrical foxbody runs and then dies going down the road band you turn the switch back off and on and it fires right up don’t even have to crank back up
22dwatkins
Boaz
foxbody runs and then dies going down the road band you turn the switch back off and on and it fires right up don’t even have to crank back up. runs great and the randomly dies and will fire eight back up. has perfect fuel flow can’t figure out what the problem is.
Check the ignition switch under the dash, it's mounted to the steering column and has special screws that fasten to the column. This may help:
replaced the switch that’s not it
Here's 1 idea, check that the coil mount, where it screws into the fender is tight. It might appear and feel tight and grounded but its a not a very solid and tight ground/connection. Mine would start, then not.. And i remounted the coil tightly and has been consistent now.
