FR500 sizing vs 1966 5bolt sizing
  • Thread starter Thread starter Weatherby
  • Start date Start date Jul 17, 2011
W
Weatherby
9
  • Jul 17, 2011
Right off the bat I just want all to know I'm still searching but thus far haven't found what I'm looking for just yet... So I'll ask and see ... and if I find one via search I'll delete this one.
Now on to the question:
Is there any chance for FR500 rims to fit on a vintage '66 289 auto notch back? I wouldn't go any larger than 17" diameter wise but I'd want to go as wide as possible both in front and back.
Also, how does "backspace" relate to "offset" terminology wise? I have another car I've researched wheels for and I know all about that car's offset etc but there doesn't seem to be much talk about vintage mustang offset but tons about backspace.... Are the terms related at all? For instance how would the +48mm offset of my other car's rims relate to the '66s proper fit?
Thanks for any help... Still searching btw... :stig:
golf4283
1,253
Orland Park, Illinois
Jul 17, 2011
  • Jul 17, 2011
If you're going to be putting on those wheels. just get the standard backspaced ones for the 1999-2004 Mustangs and use a 1" wheel spacer all around. They should be fine then. depending on tire size you might have to roll the fender lips for clearance sake.
66Runt
680
Jul 18, 2011
  • Jul 18, 2011
Try this for a pictorial showing backspace and offset.
https://www.rsracing.com/tech-wheel.html
BTW: this was the first website that came up on a quick Google search.
As you'll figure out after reading this site, to use the FR500 wheels, you'll need adapters. And you'll probably find they are kind of wide. Especially on the front, where an 8" wheel with a 235 is about as big as will fit, without mods.
Good luck with your search,
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
J
The Money Pit
  • jessie Clark
  • Sep 14, 2024
  • The Welcome Wagon
The Welcome Wagon Sep 14, 2024
89ripper
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
