Front end wheel alignment
  • Thread starter Thread starter redone
  • Start date Start date Mar 17, 2004
R
redone
40
  • Mar 17, 2004
After performing the Granada swap on '66 Coupe, I noticed that one tire always seems to turn more than the other. Example - if I am turning right, then the right tire will have a sharper turning angle the the left and vice versa when turning left.
It's this normal? Or is there an adjustment that needs to be done to the front end suspension setup?
red65
411
Ann Arbor, MI
Mar 17, 2004
  • Mar 17, 2004
Known as "Ackerman steering" the inside wheel turns more than the outside to reduce (or theoretically eliminate) scrub when turning. You should have to look pretty close to see the difference between the two sides, even at a steep turning angle, so if it's more pronounced then 'step back, stare at it a while, and pretty sure I can see a difference' check to make sure there isn't another problem (bad front end alignment, loose ball joints or bushings etc)
R
redone
40
  • Mar 17, 2004
Thanks Red but I think mine is too severe. I'll have another look at the tie rods this evening. Could be just a minor adjustment.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
